Why different bikes have different gear movements
Discussion in 'Motorbike Technical Discussion' started by Binu jose, Jul 22, 2003.
  1. Binu jose
    Binu jose Guest
    Hi
    I have a doubt , I found that almost all bikes have different
    movements for up ing and downing the gear(In some bikes gear downs
    when the front foot is pushed down on gear lever). Also the position
    of neutral gear is also different. pls tell me why such different
    system?
    Thanks
    bnujos
    Stephen Malbon, Jul 22, 2003
  3. Binu jose
    bowman Guest
    The current left hand placement of the shifter is also relatively recent as
    far as being standard. Even more fun is the suicide clutch, hand shifted
    HD's of my youth.
    bowman, Jul 22, 2003
  4. Binu jose
    Eric Goforth Guest
    Hello,
    I ride a Norton, but started riding a Japanese bike.
    The Norton shifts on the right side and down is up, neutral is between first
    and second. Most British, Italian, and Spanish bikes of the era also
    shifted on the right. Some British bikes, Triumphs, and I believe BSA's,
    shifted with up for up. I believe that there were a few older (Spanish?)
    bikes that had a shifter shaft on both sides, so you could shift on the side
    you preferred. Older Harley Sportsters also shift on the right.
    I don't think that what side you shift on makes much difference. However,
    although shifting down for up sounds backwards, it is easier to do quickly,
    which is why most purpose-built race bikes are set up to shift this way.
    It's easier to tap your toe quickly than raise it.
    There is somewhat of an advantage to shifting on the right, again in racing.
    Most race tracks are counterclockwise, so shifting on the right puts the
    shifter on the high side where your toe won't get trapped under the shift
    lever as often. Flat track bikes (where all turns are left) shift on the
    right for this reason. I believe that flat track bikes also brake on the
    right. I think that this is reason that Harley Sportsters used to shift on
    the right, so they could be potentially used in flat track racing, plus the
    fact that they were made to compete with British bikes.
    I've heard some explanations for shifting on the right in Britain having to
    do with the crown of the road and which foot you put down on the ground and
    which foot you used to stop the bike from rolling, but this won't work in
    Italy.
    I really don't understand why kickstands are on the left side countries
    where you drive on the right hand, it would make a lot more sense to me if
    they were on the right, so that the bike was leaning down the crown of the
    road. My old Honda's kickstand was on the long side and it never felt very
    secure on a road with much of a crown.
    -Eric
    Eric Goforth, Jul 24, 2003
  5. Binu jose
    Binu jose Guest
    Thanks SteveM, good information. then what u say abt the position of
    neutral in the gear sequence (like 1-n-2-3-4 in yamaha Rx 100,
    4-3-2-1-n in suzuki and n-1-2-3-4 Hero honda), is there any tecnical
    advantage or usablility advantage
    Binu jose, Jul 24, 2003
  6. Binu jose
    Binu jose Guest
    Thanks Kaybearjr, this is good information
    Binu jose, Jul 25, 2003
