Why didn't anyone tell me bike indicators don't self-cancel?
Discussion in 'UK Motorcycles' started by Tim Downie, May 10, 2011.
  1. Tim Downie
    Tim Downie Guest
    Whilst riding round the block to line up for my emergency stop, I managed to
    forget to cancel my indicators on 3 out of the 4 turns - twice. ;-)
    Apart from that, didn't have any particular problems pootling around on a
    Honda 125 today to do my CBT. The gears did my head in a bit when slowing
    down and I kept going *up* through the grears rather than down but I dare
    say a bit more practice will sort that.
    Tim
  2. heh heh - in the days of the man standing by the side of the road, if
    he'd seen one of my right hand turns I'd have never passed!
    indeed it will. Then ride a race spec bike with an upside down gear
    box and back to square one (so says my mate who managed to get a go on
    a "3 years old" WSB a few years ago - of which I'm still jealous).
    cheers
    SS
    Spinning Spanners, May 10, 2011
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Spinning Spanners
    A British bike will do the job very nicely. "Upside down" *and* on the
    other side.
    It suddenly occurs to me that I really don't know why the Japanese went
    with their orientation and side for the gears. But I'm certain someone
    here will enlighten me.
    Wicked Uncle Nigel, May 10, 2011
  4. Tim Downie
    Ian Guest
    Just make the indicators part of your "new road check". You'll get
    it. I've no idea why all bikes don't have audible indicators by
    default. It's got to be a 10p part, Shirley.
    Ian, May 10, 2011
  5. Tim Downie
    Mups Guest
    70's and 80's Yamahas had self canceling indicators.
    Mups, May 10, 2011
  6. Tim Downie
    YTC#1 Guest
    Yes, it it still works on my XJ900F.
    And on the Peg, but I don't think it is meant to :)
    YTC#1, May 10, 2011
  7. Tim Downie
    YTC#1 Guest
    YTC#1, May 10, 2011
  8. Tim Downie
    Jeremy Guest
    My bloody k1200s does and it's a pain in the arse (well could be a pain
    in any part of the body as they choose to self-cancel midway round a
    roundabout).
    Jeremy, May 10, 2011
  9. Tim Downie
    Salad Dodger Guest
    Apparently:
    "..., in America, the DOT (Department Of Transportation) deemed that
    any bike made or imported into the U.S. from 1975 on would have the
    brake on the right, shift on the left."
    Salad Dodger, May 10, 2011
  10. Tim Downie
    Nige Guest
    Mine didnt?
    Well, it might have....
    Nige, May 10, 2011
  11. And 1980s-90s Kawasakis (some). And plenty of BMWs.
    The Older Gentleman, May 10, 2011
  12. Tim Downie
    Brian Guest
    snip
    But only some Brit bikes, I seem to remember that Triumphs were one up
    and three down, BSA on the other hand were one down and three up. Both
    of course were on the correct side (right). It took me ages to get
    the hang of the foriegn layout, lots of wheel locking as I went for a
    higher gear on the right hand side.
    Brian
    Brian, May 10, 2011
  13. Tim Downie
    Nige Guest
    I rarely give advice on how to ride, but i will give you one bit that as a
    car driver you probably wont do from the start. Right turns from a main road
    onto a narrower road i observe many riders going too far wide & almost
    clipping the kerb. When approaching the right turn, dont put your front
    wheel adjacent to the middle white line of the right turn road IYSWIM, stop
    a little further back & & it just gives you a bit more room to turn
    smoother.
    Works for me.
    Nige, May 10, 2011
  14. Tim Downie
    Simon Wilson Guest
    It all depends. I have BSAs that are up for up, and also one that is
    down for up. Then I have a Triumph that is down for up, but only because
    it has rearset footrests and the gear lever is flipped around.
    Simon Wilson, May 10, 2011
  15. Tim Downie
    Ian Field Guest
    The one on the XS250 I had years ago was such a PITA, I pulled the wires off
    that go to the reed switch in the speedo.
    IIRC the indicator button returned to the centre position by a spring and
    the indicator was manually cancelled by pressing the indicator button
    without ant sideways movement - which was also a PITA.
    Ian Field, May 10, 2011
  16. Makes sense and a modicum of safety, too.
    I don't know if this is the reason, but it's merely one I put up for
    consideration...
    If you're cornering hard left and a bump or object knocks your foot up,
    you will change up mid-corner and be a fair bit safer than a sudden
    down-change, which might break rear wheel grip in wet conditions.
    As to the orientation and side, that was legislated in the USA, some
    forty or more years ago, so the Japanese (and any other nation of bike
    makers) had to comply if they wanted to sell in N.America.
    Grimly Curmudgeon, May 10, 2011
  17. Tim Downie
    Andy B Guest
    My 15 year old K1100 has self cancelling indicators that still work...
    Many years ago I was told that the Yamaha ones from the '70s were
    dropped because they had an audible warning that might have confused
    blind people into believing they could cross the road at a pelican
    crossing and all of a sudden they'd be wedged on the front mudguard of a
    motorbike.
    Andy B, May 10, 2011
  18. Tim Downie
    Hog. Guest
    They were audible? I don't recall that. I'm pretty sure my RD's self
    cancelled though.
    My R100S had the bleeper, was one of the first things owners ripped out.
    Hog., May 10, 2011
  19. Tim Downie
    Ian Field Guest
    You can do a "clicking" audible indicator with a mylar cone speaker and a DC
    blocking capacitor.
    There used to be frequent reworking of bleeping indicator warnings in
    various electronics hobby magazines, but as someone else mentioned
    elsewhere, these have been known to confuse blind pedestrians into thinking
    its the cross now signal on pelican crossings.
  20. Tim Downie
    Or a lowly CZ 250, for that matter.
    Pip Luscher, May 10, 2011
