Who thinks this is dodgy?
Discussion in 'Classic Motorbikes' started by The Older Gentleman, Dec 27, 2005.
  1. it is a fact that it's getting bloody boring.
    Austin Shackles, Dec 27, 2005
  2. The Older Gentleman
    Big Dave Guest
    Yeah.
    I got one I need doing.
    Wonder who did it....
    Big Dave, Dec 27, 2005
  3. The Older Gentleman
    Ken Guest
    No actually this bike wasnt "sussed" by TOG.............all his post
    showed was what a clueless twat he is!
    k
    Ken, Dec 28, 2005
  4. The Older Gentleman
    Ken Guest
    Ah the black paint "rebuild"............just the sort of thing TOG
    might be capable of!
    k
    Ken, Dec 28, 2005
  5. The Older Gentleman
    Guest Guest
    <plonk>
    Regards,
    Simonm.
    Guest, Dec 28, 2005
  6. The Older Gentleman
    Ken Guest
    Ahh a UKIP supporter.................these loonys dont seem to be that
    far from people like the BNP etc etc...............
    k
    Ken, Dec 28, 2005
  7. The Older Gentleman
    Ken Guest
    When are you going to "realise" that TOG, is almost certainly even more
    clueless that you are?
    k
    Ken, Dec 28, 2005
  8. <Bad form post>
    And even sillier sod won it for £530.
    And I've just noticed that the whizzo restoration didn't extend to
    putting a sidestand on it.
    And the front guard is one of those pattern things - nowt wrong with
    them per se, but I'd at least cut off the mounting bracket extension
    that bears the additional mounting holes for larger front wheels.
    A rear mudguard would have been nice, too.
    I wonder what the lucky auction winner will do when/if he discovers that
    he's bought a messed-with XS250 and not a genuine XS400?
    To convert a 250 to a 400, all you need to do is bore out the barrels. I
    think the carbs are the same. However, the 400 has a different
    crankshaft with a different balance factor, to allow for the higher
    reciprocating weights, and thus a simple bore-out means the bugger
    vibrates even worse than normal. A straight engine swap, of course, is a
    different kettle of fish.
    The Older Gentleman, Dec 28, 2005
  9. Do you think when he goes looking for other pervs, he plays "sub"? It
    would explain a lot.
  10. The Older Gentleman
    Ken Guest
    Maybe this forum is the only place where you can find others who have
    even less knowledge than you?
    k
    Ken, Dec 28, 2005
  11. The Older Gentleman
    Ken Guest
    Ok then Andy m8.............would you or TOG be able to rebuild a
    spoked wheel accurately, or make a professional repair on a broken set
    of crankcases?
    Lets get away from the toss you post on here, and see if either of you
    can actually do anything in real world terms!
    k
    Ken, Dec 28, 2005
  12. The Older Gentleman
    Ken Guest
    Either of these bikes are utter and complete crap...............the 250
    would probably be better as insurance would be cheaper!
    k
    Ken, Dec 28, 2005
  13. I can't remember if sweller ever flogged his XS400.
    I quite liked the couple I owned, in a sort of ShiteOldWorkingBike way.
    The engines were definitely torquier than most other 400 twins of the
    era (the Z400/440 was an honourable exception[1]), and they didn't
    handle badly, but the weak electric start was always the bike's Achilles
    heel. At least they fitted a kickstarter.
    [1] That one I ran for a year or so was a *lovely* little hack. You may
    remember Petrolcan bought it, and then some nameless shit nicked it.
  14. Wotcha.
    How about a professional repair to a casting, which then needed lacing to a
    wheel rim ?
    http://www.moonshiners.org.uk/frontdisc.htm
    Sometimes it's a case of having to do it.
    "If you can't buy it - then you must build it"
    ^..^ Lone Wolf, Dec 28, 2005
  15. The Older Gentleman
    Ken Guest
    Looks an excellent job...........having some castings done at the mo,
    in regard to tooling for making alloy tanks.
    k
    Ken, Dec 28, 2005
  16. The Older Gentleman
    Andy Wegg said...
    Weird that. I owned an XS400 and a 400N, I prefered the Honda. I also
    owned a rat-bike XS250 for 3 years. Slow as ****, and took forever to
    start unless fitted with B8EV plugs, but it was one of the most reliable
    bikes I ever owned. I liked the 250 more than the XS400, I always
    thought the chassis wasn't up to 400 performance, but could just cope
    with the 250 lump.
    Lozzo, Dec 29, 2005
  17. The Older Gentleman
    Ken said...
    I did both of these last year. I'm pretty sure both TOG and Andy can
    too.
    I can, and regularly do.
    Lozzo, Dec 29, 2005
  18. Being honest, I have never attempted a wheel rebuild and I have no
    welding skills. However, I wouldn't consider these the be-all and
    end-all of bike restoration. I've lost count of the number of engines
    and bikes I've rebuilt.
    And I've owned 300-odd bikes in the last 30 years, of course.
    <AOL>
    You look back on some projects and think: "That was worth it...". Like
    the 400 Four, and sorting out the camchain tensioner by going in through
    the sump, which is *definitely* not a solution mentioned by Honda or
    haynes in their respective manuals...
    And you look back on others and think: "What a waste of time that
    was..." Like the CB500T. I see some classic dealer has got one up for
    grabs at about £1500. What's sad is that some twonk may buy it.
    The Older Gentleman, Dec 29, 2005
  19. The Older Gentleman
    I thought "suss", certainly the schoolboy version, was derived from the
    police SUS powers.
    sweller, Dec 29, 2005
  20. The Older Gentleman
    £261 on ebay - bloody cheap for a 400 with 12 months ticket I can't
    remember if it had tax - I may have got £350 ish in the local Friday-Ad.
    Probably right for the dog that it was. Awful thing.
    http://www.sweller.dynalias.org/xs400/
