Which sport filter ?
Discussion in 'Motorbike Technical Discussion' started by traxman, Jan 8, 2006.
  1. traxman
    traxman Guest
    Hi!
    I'm an owner of kawasaki Z750 ('04) and I would like to make a little
    tunning on my bike. Last year I bought an open exhaust, which is a
    replica of akrapovic, and now for this season I would like to make
    another upgrade. And that would be a sport filter. Here in Croatia I
    can find BMC, DNA and K&N. The paarice unimportant, because it's
    almost the same. On internet(google) I couldn't find any reviews,
    tests, compares of them. So now I'm in dilemma. In general for K&N
    filters I heard that they became worse, BMC are OK but I'm skeptic
    with italian products. For DNA I don't have any info. So if some have
    any good advice I would be very grateful.
  2. K&N
    ROBERT MILLER, Jan 11, 2006
  3. traxman
    traxman Guest
    Any special reason why?
    traxman, Jan 11, 2006
  4. Because.
    The Older Gentleman, Jan 11, 2006
  5. traxman
    John Johnson Guest
    <rhetorical question>
    What exactly do you think that this filter will do for you?
    </rhetorical question>
    Most of the non-testimonial reading that I've done (though it's
    difficult to find good quantitative data on these things) indicates that
    the OEM filter is comparable (or superior) in terms of air flow in
    recent vehicles. Similarly, the OEM filter is typically comparable (or
    superior) in terms of filtration in recent vehicles.
    If you want a permanent (e.g. K&N) filter to save money, cut down on
    waste, or something similar, that's an entirely different issue.
    Later,
    John
    John Johnson, Jan 12, 2006
  6. traxman
    SoCalMike Guest
    if the OEM filter is foam, theyre easily cleaned as well as "free" with
    the cost of the bike.
    any particular oil i should be using on my OEM foam filters?
    SoCalMike, Jan 13, 2006
  7. any good airfilter oil will do fine. (Dont spray on heavy, just a light
    coat.) K&N use may need rejetting. Unless go with a OEM K&N fliter. Still
    the way to go.
    ROBERT MILLER, Jan 13, 2006
  8. traxman
    Catspit Guest
    I added a Power Commander and a BMC Race air filter to my Yamaha R1
    last year with the specific goal of smoothing out the hideous chasm in
    the midrange powerband. I found that the combination worked very well
    and I don't get the 'honking' at 5.5k rpms any more. The BMC does claim
    to require a custom power commander fuel map to work properly, which is
    something I will test this track day season. If you don't have the
    problem I had, the seat-of-pants dyno doesn't feel so different in
    performance to me so I'm not sure it's a worthwhile investment on your
    kwak. As far as quality goes, I felt that the BMC was up to par, pretty
    well made, no complaints.
    Cheers,
    /Andy
    Catspit, Jan 26, 2006
  9. traxman
    danielsmith1 Guest
    On oil-gauze type air filters (K&N, etc.):
    I have talked to a few people that have actually done testing on
    different types of filters, taking into account more than just
    performance. They also considered how well they filtered. I can be
    pretty sure they were unbiased. They were from a very well known,
    reputable, and well equipped performance development facility. They
    said, to my suprise that they prefer standard issue paper filters.
    Here is why they don't like oil-gauze filters like K&N. When they are
    new and freshly oiled, it is difficult to oil them properly so that
    they do not become too restrictive from excess oil. When oiled
    properly, they work well for a while, but then the oil tends to dry out
    rather quickly. At this time they flow very well, but let a lot of junk
    through. They found that in the interest of making their engines last
    and perform reasonably well and very consistently that paper filters
    were the simplest and most effective solution.
    This may not deliver the most peak power, but I really doubt that you
    will be able to notice the power difference between a properly sized
    and mantained paper filter and a K&N filter. And don't trust dyno
    testing results on air filters. It is somewhere between difficult and
    impossible to get dyno readings repeatable enough when doing such
    testing.
    danielsmith1, Jan 29, 2006
  10. A hundred tuning shops will be interested to read that.
    The Older Gentleman, Jan 29, 2006
  11. So will the racers
    ROBERT MILLER, Jan 29, 2006
  12. traxman
    opietaylor69 Guest
    Re: Which sport filter ?
    Group: rec.motorcycles.tech Date: Sat, Jan 28, 2006, 8:24pm (EST-3)
    When they are new, they are pre-oiled, and do not require oiling.
    Cleaning and oiling (which you might not have to do for a year or more,
    depending on use and condition) is easy and straight forward. The oil
    does not "dry out quickly", it lasts for a very, very long time. On
    some motors, K&N's make a significant increase in power, on others,
    much less. But if you're going to knock 'em, at least try having some
    experience using them.
    opietaylor69, Jan 30, 2006
  13. I have K&N's on my Kat, the 2 into 1's. Just cleaned them this month. My
    fever is starting early. I think what he said is bull. I use K&N's in my
    cars. One had over 250000 on it before it go hauled off, it was a 1989
    olds. If the filter didn't do its job, I don't think the olds would made it
    that far. But the 89 olds didn't die, I used it for parts for the 1988
    olds. That I was restoring. The same K&N filter out of the 89 is now in the
    88. Easy to clean, nice improves to a point. Will out last any paper type,
    then some. Try any brand of cotton filter before you put them down. I like
    K&N. If you don't get your hands dirty, how do you know? Don't assume,
    ask! And don't believe everything you read.
    ROBERT MILLER, Feb 1, 2006
  14. traxman
    danielsmith1 Guest
    I have used them, K&N filters specifically, in a very harsh
    environment. As far as filtering goes, I'd trust a paper filter over
    them any day.
    I grant that they --potentially-- offer power gains, and they are more
    suitable in certain applications.
    danielsmith1, Feb 17, 2006
