Which is the best product to Lube a motorcycle chain
Discussion in 'Motorbike Technical Discussion' started by Gixxerman, Apr 18, 2007.
  1. Gixxerman
    Albrecht Guest
    "He dreamed that he stood in a shadowy Court,
    "Where the Snark, with a glass in its eye,
    "Dressed in gown, bands, and wig, was defending a pig
    "On the charge of deserting its sty."----Lewis Carroll, "The Hunting
    of the Snark"
    Albrecht, Apr 21, 2007
    #41
  2. Gixxerman
    Gene Cash Guest
    "Puff, puff, give!"
    Gene Cash, Apr 21, 2007
    #42
  3. Gixxerman
    Albrecht Guest
    Don't bogart that joint.
    "The Jury had each formed a different view
    "(Long before the indictment was read),
    "And they all spoke at once, so that none of them knew
    "One word that the others had said.
    "You must know ---" said the Judge: but the Snark exclaimed "Fudge!"
    "That statute is obsolete quite!
    "Let me tell you, my friends, the whole question depends
    "On an ancient manorial right."
    ---Lewis Carroll, "The Hunting of the Snark"
    #43
  4. Gixxerman
    Pete M Guest
    I have always used gear oil, because I've heard it has properties engineered
    into it which make it suitable for a chain.
    It's supposed to behave kinda like corn starch and water, we used to play
    with this as kids. It flows if you pour it, but if you suddenly put stress
    on it, it tends to turn into a solid. Just the thing for a rolling contact.
    Something I haven't noticed mentioned is that the outermost roller of the
    chain isn't permanently lubricated like the bits protected by the lubricant
    captured by the o-rings, and you probably want some proper lubrication where
    the sprocket tooth strikes this roller as well, because alot of wear occurs
    there, which tends to effectively increase the pitch dia of the sprocket,
    and the chain is forced to wear to accomodate this.
    I apply it at the end of a ride,about every 600 Km, the excess drips off
    while it's parked. There's still some thrown off, but some gunk on a paint
    brush gets rid of it all when I give it a wash to get the bugs off.
    My 1200 has 36000 Km on it, It tried to measure the chain stretch a with a
    pair of Verniers not long back, I took a measurement of the distance between
    a number of links, with a weight hung off the bottom, inside and outside the
    rollers and came up with an average. I think it was something like 0.008"
    average per foot. I don't know what the current acceptable max stretch is
    but I think in an old Triumpth manual I had, it gave 1/8th in per foot! Holy
    crap. I would have thought your chain and sprockets would have been toast
    long before this.
    My vote is for gear oil anyways...
    P.
    Pete M, Apr 21, 2007
    #44
  5. Gixxerman
    Scott Guest
    From what I've read, it also contributes to leaking forks. The smart move,
    obviously, is to always use *fresh* seal oil on fork seals.
    It might explain why daily bathing is a fairly recent invention.
    -Scott
    Scott, Apr 21, 2007
    #45
  6. Gixxerman
    Albrecht Guest
    It's worn out.
    0.004 to 0.005 per link is the typical wear limit in my manuals.
    My Honda CR250M's manual tried to claim that the chain was worn out
    when the wear per link was only 0.001.
    I called bullshit on that idea...
    "In the matter of Treason the pig would appear
    "To have aided, but scarcely abetted:
    "While the charge of Insolvency fails, it is clear,
    "If you grant the plea 'never indebted.'
    "The fact of Desertion I will not dispute;
    "But its guilt, as I trust, is removed
    "(So far as relates to the costs of this suit)
    "By the Alibi which has been proved."
    ----Lewis Carroll, "The Hunting of the Snark"
    #46
  7. Gixxerman
    Leon Guest
    long before this.
    P.[/QUOTE]
    The simplest test is to try to pull the chain away from the sprocket.
    If it can be pulled away, the chain and sprocket are knackered.
    Leon
    Leon, Apr 21, 2007
    #47
  8. Gixxerman
    John Johnson Guest
    Phosphates have been banned from household detergents in the US for many
    years now (maybe since the early 1980's? I'm too lazy to look it up).
    Nitrates can cause algal blooms too, and farm runoff is typically high
    in nitrates. Household laundry, etc. is typically pretty low in nitrates.
    Later,
    John
    John Johnson, Apr 21, 2007
    #48
  9. Gixxerman
    John Guest
    I use chainsaw oil. It has a sticky consistency and doesn't throw off much.
    John
    John, Apr 21, 2007
    #49
  10. Gixxerman
    Albrecht Guest
    #50
  11. Gixxerman
    John Johnson Guest
    So ask your family how they know whether or not they're overfertilizing.
    Unless they've had someone do soil chemistry testing on the farm, and
    come up with a picture (at some resolution or other), you really only
    know when you back off enough to hurt the crops....which most farmers,
    IME, aren't terribly interested in doing.
    But whether or not farmers are over-fertilizing in large numbers is a
    side issue. We know that nitrates are getting into the water, and if
    they're getting into surfacewaters (lakes, rivers), then it's obvious
    that they're not all going into the subsurface. Sources matter if you
    want to try and reduce usage. Household usage was reduced (but not
    eliminated) by removing TSP from laundry detergents. I'd be happy to see
    less of the stuff in the rivers and lakes, and will leave it to the
    professionals to determine which vectors make the most difference. If
    they say farm runoff, well I'll believe them until someone shows me some
    evidence to the contrary.
    The point is, common sense, intuitions, and "farmers are cheap" type
    arguments are unreliable, because you can come up with a bit of common
    sense, or an anecdote to support almost any conclusion at all. What
    matters is the evidence, which has been collected, even if I don't know
    what it says is the most significant source of nitrates right now.
    Phosphates from household cleaners used to be a much bigger source than
    they are now, and that the removal of TSP from laundry detergents was a
    direct result of studies finding lots of phosphates in water downstream
    of sewage outlets.
    Later,
    John
    #51
  12. Interesting figure. I'm surprised it's so high (mileage, and fuel
    economy, that is)
    The Older Gentleman, Apr 21, 2007
    #52
  13. Gixxerman
    Roger Hunt Guest
    The Older Gentleman wrote
    Some fairly recent figures here, in amongst the article, but they need
    more work than I'm prepared to put in at this moment.
    http://tinyurl.com/27nvev
    Roger Hunt, Apr 21, 2007
    #53
  14. Very, very interesting. Thanks.
    I wonder why fuel economy ranks so low as a US priority, when there are
    so many really good economical performance cars out there?
    Because fuel's cheap, I s'pose.
    #54
  15. Gixxerman
    Roger Hunt Guest
    This'll hurt your brain - Bureau of Transportation Statistics :
    http://www.bts.gov/
    Too cheap, and we've these ****-witted ideas of centralisation that
    encourage road use. And anyway, how are we expected to get to the
    sodding East Midlands mega-Tesco after the oil's run out? Bah.
    #55
  16. Gixxerman
    Roger Hunt Guest
    Weekly U.S. Retail Gasoline Prices, Regular Grade ($/USgal, inc taxes)
    http://tinyurl.com/ibjj
    This is excellent stuff, and the links look promising too.
    Are there sites like this over here?
    #56
  17. Gixxerman
    Pete M Guest
    0.008" per foot is what I came up with, not per link, measuring across 10
    links at a shot.
    Actually I think I mean pitches.... what's the right definition of a "link"
    anyway? :eek:) Intuitively this is the distance between the rivets... but you
    can buy a "half link" :eek:)
    Maybe some potential material for George Carlin ...
    Couldn't find a chain stretch spec in my shop manual, just some diagrams
    showing an exaggeration of a normal and worn sprocket. You'd they could do
    better for $100, the thing doesn't even have an index at the back. Seems to
    me those manuals tend to be marginally adequate in their info sometimes. But
    when you need one, you need one, and I've never been sorry I sprung for one.
    My method probably has some flaws in it, but I got the idea that if I
    couldn't get some obviously bad numbers, it's probably still OK.
    P.
    Pete M, Apr 22, 2007
    #57
  18. Gixxerman
    Albrecht Guest
    Suzuki repair manuals usually call for counting out 21 pins, which is
    20 links plus one pin. Measure across the 21 pins with the opposite
    run of chain pulled tight.
    Multiply the pitch times 20 to get the length of a new run of chain.
    520/525/530 chains have the same pitch, with is 0.625 inches. The
    service limit on a 520/525/530 chain is 12.60 inches. If a new chain
    would measure 12.50 inches, 0.100 is the total wear.
    0.100 divided by 20 = 0.004 inches of wear per pin.
    A link has two side plates, two pins, two bushings, and two rollers.
    But a half link has the same number of parts. It's just that the
    roller
    on the small end of the half link has to replace one roller of a
    regular link.
    The chain measurement diagram is in the maintenance chapter of my
    GSXR750 shop manual. Most home repair manuals are taken from the
    official manual.
    If you have a chain that's worn 0.008 per pin, it's worn out and has
    been for some time.
    "When the verdict was called for, the Jury declined,
    "As the word was so puzzling to spell;
    "But they ventured to hope that the Snark wouldn't mind
    "Undertaking that duty as well.
    "So the Snark found the verdict, although, as it owned,
    "It was spent with the toils of the day:
    "When it said the word "GUILTY!" the Jury all groaned,
    "And some of them fainted away."
    Albrecht, Apr 22, 2007
    #58
  19. The Older Gentleman, Apr 22, 2007
    #59
  20. Gixxerman
    Roger Hunt Guest
    Roger Hunt, Apr 22, 2007
    #60
