Which fully synthetic oil .....
Discussion in 'UK Motorcycles' started by Nidge, Oct 11, 2004.
  1. Nidge
    SteveH says...
    One bike runs to 100K ok and that's a big thing? OK, Google again and
    tell me how many hits you get regarding clutch slip when using car oil.
    Lozzo, Oct 12, 2004
    #61
  2. I had a Renault 20 that did that. I used five litres of oil to get to
    Brighton, and five litres back again. As the journey was about 15 miles
    each way, I'd say that was rather a lot.
    Whinging Courier, Oct 12, 2004
    #62
  3. Nidge
    SteveH Guest
    _some_ car oils. Those with fancy friction reducers in them.
    As I've already said, a bog-standard semi-synth will, in 99% of cases,
    cause no ill effects whatsoever.
    It seems this is backed up by proper chemical research.
    There will always be exceptions in the same way that not all bike oils
    are good for all bikes, and not all car oils are good for all cars.
    SteveH, Oct 12, 2004
    #63
  4. Nidge
    Andy Hewitt Guest
    Aye, but guess who makes Selenia oil?
    Andy Hewitt, Oct 12, 2004
    #64
  5. Nidge
    SteveH says...
    And those that don't have them aren't worth buying for a decent car
    engine, so why put them in a bike engine that is even more stressed?
    Less than 99% I think
    So why take the chance just to save having 2 bottles of oil in the
    garage? Your logic is pretty fucked up imo. You keep running the VFR on
    car oil, Steve. It's not like your bike engine gets stressed, but with
    regard to Nidge's ZX-6R, he'd be foolish to run it on shitty old Castrol
    GTX the way he rides.
    GTX was developed way back in the days when long stroke, lazy engines
    like the Morris Minor's were the norm. Imo it isn't suitable for the
    high revving powerful engines that are built to tighter tolerances we
    have today. Horses for courses, and all that.
    Lozzo, Oct 12, 2004
    #65
  6. Nidge
    Preston Kemp Guest
    There is a published study somewhere on the web from when a lab tested
    car vs bike oil, specifically looking at the areas where bike oil is
    claimed to be different i.e. shear strength (to cope with gearboxes) &
    the effect on wet clutches.
    IIRC they didn't find any difference between the majority of oils, &
    specifically hightlighted that some cheap car oils were better than
    vastly more expensive bike oils. Incidentally statistics show this
    topic accounts for 86% of all internet traffic, the other 14% being how
    to scrub in tyres.
    Preston Kemp, Oct 12, 2004
    #66
  7. Nidge
    Stritchy Guest
    10 year old research
    http://www.xs11.com/stories/mcnoil94.htm
    Stritchy, Oct 12, 2004
    #67
  8. Nidge
    Lozzo, Oct 12, 2004
    #68
  9. Nidge
    Or a Guzzi; Trex suffices in these cases
    sweller, Oct 13, 2004
    #69
  10. Nidge
    Preston Kemp Guest
    That may be true, but it doesn't mean the differences between car &
    bike oil are any greater now than they were then. Clutch slip is
    undoubtably an issue with *some* oils in *some* bikes, but that's most
    likely down to the blend of the oil rather than whether it's
    specifically for cars or bikes. For example KTMs are known to have
    problems with one particular brand of fully synth bike oil, but not
    others.
    The argument that fully synth car oil isn't 'good' enough for modern
    high performance bike engines doesn't add up in my opinion. The
    bearings in a turbo are the hardest challenge for any oil - far harder
    than any part of an engine.
    Despite that, I still choose to use bike specific oil, and always have
    done.
    Preston Kemp, Oct 13, 2004
    #70
  11. Nidge
    Zymurgy Guest
    Lozzo wrote
    Heh, cool, are they still doing this deal ?
    Hmm, where's the closest Heinz Gherkin in the city then ...
    P.
    Zymurgy, Oct 13, 2004
    #71
  12. Nidge
    To a point I think... car oils have a different additive package to bike
    oils, and takes into account things like wet clutches.
    It doesn't make much difference how much the engine revs, above 1500 or
    so rpm hydrodynamic lubrication occurs[1], and proper hydrodynamic
    lubrication relies a lot on the oil being the right viscosity, as in the
    10W-40 bit. The other important bit, is using an oil with enough film
    strength for the application it's used for, this is why performance
    engines require synthetic oils... Synthetic oils being more resistant to
    break down and require less additives to keep them in grade, meaning
    more actual oil content getting to your bearings.
    [1]I know there are places that hydrodynamic lubrication don't occur,
    but depend more on film strength[2]. :)
    [2]Boundary Lubrication.
    Muck, Oct 13, 2004
    #72
  13. Nidge
    Preston Kemp says...
    While I accept some points, there is always the argument that over the
    last 10 years bike engines have developed further than car engines. They
    also need better oil as they are that little bit more fragile. Aprilia
    Mille engines suffer with clutch slip no matter what fully synth you
    use. The factory recommend a semi-synth be used.
    Turo bearings subject the oil to heat more than anything else. They
    don't subject it to shear and aeration in the way a bike gearbox does.
    I do for my modern engines, I use any old crap in the Honda 250.
    Lozzo, Oct 13, 2004
    #73
  14. Nidge
    Zymurgy says...
    Yes, carried over to this year's catalogue. I bought some for the
    Thunderace before I sold it, and will be getting some for the ZX-9R this
    weekend. Apparently they show air filters for both these bikes in the
    catalogue, but supply is as bad as it ever was. I ask them to supply a
    Bandit air filter or an RF900 one instead cos I can pass that on to a
    friend and they then owe me a favour :)
    Stockwell, Gants Hill or Welling are all within easy reach?
    Lozzo, Oct 13, 2004
    #74
