Which fully synthetic oil .....
Discussion in 'UK Motorcycles' started by Nidge, Oct 11, 2004.
  1. Nidge
    Salad Dodger Guest
    You are George W Bush, AICMFF Weapons of Mass Destruction.
    What do mean "there aren't any"?
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16589.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Oct 12, 2004
  2. Nidge
    Lozzo was seen penning the following ode to ... whatever:
    And you'd be surprised how many people would be proud of the tenner
    they saved...
    Timo Geusch, Oct 12, 2004
  3. Nidge
    Stritchy Guest
    Castrol GTX is a mineral oil not a semi-synth
    http://www.castrol.com/castrol/productdetailmin.do?categoryId=82915280&contentId=6008816
    GTX Magnatec is semi-synth
    http://www.castrol.com/castrol/productdetailmin.do?categoryId=82915278&contentId=6008753
    and I have been advised that the "unique synthetic ester that clings
    to the engine surfaces like a magnet" can play havoc with wet
    clutches.
    If you are going to put in a 15W/40 car oil into a bike engine, you
    might as well save some money and get a proprietorial brand at a
    tenner less (Magnatec £24.99 & Own Brand £14.99) because the specs are
    the same.
    Personally I use GPS, but that's because I get it cheap from the shop
    I work part time in.
    Stritchy, Oct 12, 2004
  4. Nidge
    DannyBoy Guest
    You need SL A3.
    Whether it's semi synth, fully synth or made of acid and sand [1] is
    irrelevant. If it meets the SL A3 standards it's good.
    [1] Although to be fair an oil made of sand might struggle to meet the
    SL A3 standards....
    DannyBoy, Oct 12, 2004
  5. Nidge
    DannyBoy Guest
    I use bike oil 'cos I've heard that car oils are not suitable for wet
    clutches. But whenever I try and look into *exactly* why not, the
    claim seems to evaporate.
    Can you tell me *exactly* which chemical/mineral causes the clutch
    slip?
    Are there any car oils that do not contain said chemical?
  6. Nidge
    The whole point of a synthetic is it's high film strength, which means
    it doesn't easily go away when , say a cam lobe hits it at high speed.
    This is a good thing. Yes, imho it is worth the extra £5 or so.
    Try to stick to a 10W-40 coz something like a 15-W50 won't be very kind
    to your cam shaft in the colder weather.
    Muck, Oct 12, 2004
  7. *Ding*
    I put Magnatec in my Bandit when I had it and the clutch did indeed slip
    like a bastard.
    In fact, I remember making a post about it before I put it in and
    merrily went on my way, ignoring calls of "It'll make your clutch slip"
    and similar.
    I'd only ever put car oil in my engine if there was absolutely no
    alternative and even then I'd keep the revs below 6,000 as a get you
    home remedy.
    Whinging Courier, Oct 12, 2004
  8. Nidge
    Friction modifiers, apparently. The bike oils seem to have a MA
    certification which means it's designed not to promote clutch slip.
    These days, no not really. Unless you want to put recycled 20W-50 in
    your bike.
    Muck, Oct 12, 2004
  9. Nidge
    DannyBoy Guest
    I know I should DYOR but what's MA cert and have you got a link to it
    & what exactly it tests? Ditto Friction Modifiers.
  10. Nidge
    Saying that, I put a modern 5W-40 car synthetic oil in my Bandit / CG.
    That has never made the clutches slip[1]. With the FZR, I'm keeping with
    a 10W-40 synthetic like Motul.
    [1]A dual petrol / diesel certified oil.
    Muck, Oct 12, 2004
  11. Nidge
    Steve Parry Guest
    Steve Parry, Oct 12, 2004
  12. Nidge
    Dunno, I think Loz posted a link a while ago. If you're that worried,
    write to the oil manufacturer I'm sure that they'll answer your questions.
    Muck, Oct 12, 2004
  13. Nidge
    DannyBoy Guest
    I've done some research. The only objective standards for oil seem to
    be the European and US bodies that come up with the SL A3 rating. [1]
    When people suggest other things to look for (MA cert - Friction
    Modifiers)
    and I question it the whole argument evaporates into vagueness.
    Frankly I shall continue to put the cheapest SL A3 oil in my car and
    the cheapest SL A3 bike oil in my bike until someone gives a specific
    reason not to.
    [1] Which knocks the synthetic/non synth argument on the head 'cos it
    makes no distinction between how you make the oil good and hard
    wearing - it just measures goodness and hard wear!
  14. Nidge
    Lozzo emerged from their own little world to say
    unless you have a dry clutch and a relatively low revving engine like the
    BMW Boxer
    wessie, Oct 12, 2004
  15. Nidge
    My TL actually came with Macadams on it. Pity I didn't notice when I
    bought it; I merely looked at the remaining tread. Had I checked
    properly, I'd have haggled for a new set of tyres.
    As for oil, I use bike semi synth for the TL, Mobil 1 for the Guzzi,
    cheaper car stuff for SOBs and SOCs.
    Pip Luscher, Oct 12, 2004
  16. Nidge
    dwb Guest
    So what do you do with the money you save then?
    All £5 of it :)
    dwb, Oct 12, 2004
  17. Nidge
    Ben Blaney Guest
    He bought a house in Wales.
    Ben Blaney, Oct 12, 2004
  18. Nidge () wrote:
    : For 600 super sprouts, which fully synth oil is:
    : Best for road use?
    : Best value?
    : Should I just save a fiver a time and stay with semi synthetic anyway?
    : You get a nice hat with 5 ltrs of Castrol semi synthetic, but those hats
    : make my ears look big. So probably I shouldn't be too swayed by that. Now
    : if they did a cod-piece.....
    : Umm anyhow which oil, is really it worth the extra?
    I've owned my CBR6 from new and used Castrol GP (mineral) for the first
    20,000 miles then switched to Castrol GPS (semi synth). It turned 79,000
    miles at the weekend and hasn't had any problems so far. It might need a
    camchain sometime soon but given Honda's reputation for dodgy camchains
    and tensioners that's not bad going. The oil and filter has been changed
    every 4,000 rather than Hondas recommended 8,000. Oil is (relatively)
    cheap.
    Blair.
    '97 CBR600
    B.G. Finlay IT Services, Oct 12, 2004
  19. Nidge
    dwb Guest
    Yeah but you change oil more than once a year....
    dwb, Oct 12, 2004
  20. Nidge
    dwb Guest
    Lozzo sed
    Is that all?
    dwb, Oct 12, 2004
