Which fully synthetic oil .....
Discussion in 'UK Motorcycles' started by Nidge, Oct 11, 2004.
  1. Nidge
    Nidge Guest
    For 600 super sprouts, which fully synth oil is:
    Best for road use?
    Best value?
    Should I just save a fiver a time and stay with semi synthetic anyway?
    You get a nice hat with 5 ltrs of Castrol semi synthetic, but those hats
    make my ears look big. So probably I shouldn't be too swayed by that. Now
    if they did a cod-piece.....
    Umm anyhow which oil, is really it worth the extra?
    Nidge
    ZX6R J2 Stunning in zit yellow. KX 125 MX 'I'm snot green -fly ME'. A few
    bits of CB500S in Norwegian Parrot blue. BOTAFOT#63 BOMB#5
    'Just because I don't care doesn't mean I don't understand'.
    Homer (Simpson).
    Nidge, Oct 11, 2004
  2. Nidge
    SteveH Guest
    Most likely none of them.
    Castrol GTX car oil, YKIMS.
    SteveH, Oct 11, 2004
  3. Nidge
    Nidge says...
    Unless you thrash the shit out of your bike everywhere or go racing,
    then stick to a quality semi-synth. It'll do nicely enough.
    Lozzo, Oct 12, 2004
  4. Nidge
    SteveH says...
    Those people who explore the upper limits of their bikes rev range may
    disagree. Car oils can and do cause clutch slip in some bikes.
    Lozzo, Oct 12, 2004
  5. Nidge
    SteveH Guest
    Oil is oil, unless you get problems with clutch slip (and I've yet to
    own a bike that does have a problem with this) then there's no point in
    paying extra for a picture of a bike on the bottle.
    SteveH, Oct 12, 2004
  6. Nidge
    Ginge Guest
    By the same token, supermarkets are suparmarkets.
    Ginge, Oct 12, 2004
  7. Nidge
    SteveH says...
    Shows how little you know about anything mechanical then.
    Different oils for different applications. You can't put 10W/40 in a 2-
    stroke's oil tank. A high revving tuned 2-stroke will destroy itself if
    run on mineral oil. An Aprilia RSV will destroy the clutch if fully
    synth oil is used in the engine. My old GSXR750's clutch slipped like
    **** when I topped the engine up with car oil.
    Car oil for cars, bike oil for bikes.
    Lozzo, Oct 12, 2004
  8. Nidge
    Ginge Guest
    Vegetable oil for welsh pikeys, trying to avoid tax on diesel. Do you
    sell much at work Steve?
    Ginge, Oct 12, 2004
  9. Nidge
    SteveH Guest
    Yes, yes, 2-stroke oil is different. However, the original question was
    aimed at 4 stroke engines.
    In terms of the Aprillia, there's always an exception, and the GSXR
    incident could well have been the choice of car oil causing issues.
    IME, boggo standard 15W/40 GTX is absolutely fine - I've used it in the
    following without issues:
    GSX250
    Z400J
    Divvy 600 x 2
    CBX750
    TRX850
    VFR800
    My brother has also used it in his VFR750.
    There will always be exeptions to the rule, however, IME, the rule is
    that a bog-standard semi-synth car oil is absolutely fine in a majority
    of bikes.
  10. Nidge
    SteveH Guest
    I work in England.
    Do keep up.....
  11. Nidge
    SteveH says...
    It was a quality car oil, Duckhams, Castrol or something similar.
    <snip>
    Steve, you don't push your bike engine hard enough to ever provoke
    clutch slip, you aren't at all qualified to comment on this. Your list
    of bikes contains what are fundamentally SOBs with a couple of recent
    additions that you ride/rode 'carefully'. You cannot class a high
    revving ZX-6R in the same league as any of your old shitters, and you
    haven't ridden the VFR far enough this last year to warrant giving it an
    oil change.
    Correct me if I'm wrong, but didn't your TRX lunch its original motor?
    I stand by what I say, in that car oil is for cars and bikes being
    higher revving, having wet clutches and under more stresses require bike
    specific oils.
    When I need to know about what baked beans or hi-fis are best I'll be
    graeful for your opinion, but please refrain from giving mechanical
    advice in the absence of knowledge.
    Lozzo, Oct 12, 2004
  12. Nidge
    SteveH Guest
    OK, so I ride 'carefully', but I also ride to the redline on occasion.
    On the 'bike oil' used by On Yer Bike. It was a known issue with the TRX
    engine and not related to the oil in any way whatsoever.
    This is, of course absolute crap.
    I've had a couple of trusted bike mechanics who have told me that it's
    pointless to pay extra for bike oil as it's no better for a bike than
    car oil.
    One of said mechanics posts to UKRM and I would trust on this one as
    he's a qualified car and bike mechanic.
    Am I the only one who detects a commercial interest in your approach to
    the use of a 'proper bike oil'?
  13. Nidge
    "When I want shit from you, I'll squeeze your head."
    platypus, Oct 12, 2004
  14. Nidge
    SteveH Guest
    When I want an impartial opinion I won't ask someone who has an interest
    in selling me an overpriced product.
  15. Nidge
    Lozzo recommending the use of a decent semi-synth bike oil in performance
    bikes is hardly grounds for - effectively - calling him a spamming ****.
  16. Nidge
    SteveH says...
    Again, this shows how little you know. Google for JASO MA standards and
    see what comes up.
    I trust his mecahnical expertise as well. However, our opinions differ
    somewhat on this subject.
    I no longer sell oil of any kind or description. I still choose to use a
    bike specific oil in my own machines. My current favourite is Motul from
    Hein Gericke at 24-50ukp for 5 litres, with an oil and air filter thrown
    in free of charge. How much more expensive is that compared to a quality
    car oil such as Castrol GTX when you factor in the cost of the filters?
    It's actually cheaper to buy the Motul + filters.
    Why bother running the risk of using an unsuitable oil when a good
    quality bike oil is this affordable?
    Let me put it in terms you'll understand better, it's like Tesco Value
    wheat breakfast bisks as opposed to real Weetabix. Both cost within
    pennies of each other, but Weetabix taste better and do a better job.
    Lozzo, Oct 12, 2004
  17. Nidge
    platypus says...
    Which is laughable when I don't even sell oil and have no financial
    interest in any oil company.
    Helmets is a different matter though.
    Lozzo, Oct 12, 2004
  18. Nidge
    SteveH says...
    What interest?
    Lozzo, Oct 12, 2004
  19. It was somewhere around Barstow, on the edge of the desert, when the
    Fwiw, I agree with you on this. If one is running a proper SOB, then car
    oil is fine, but I wouldn't run a modern lump like GSXR 1000 on it. Too
    much can go wrong too quickly for the saving of a couple of quid to be
    worthwhile.
    Otoh,,, I've never bought bike oil and all my bikes, being of a certain
    generation, have only experienced the luxury of oils blended for
    gentlemens' carriages.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Oct 12, 2004
  20. Nidge
    Grimly Curmudgeon says...
    I run my old Honda on cheapo Motorway 20/50 car oil. It was designed and
    built 25 years ago, before all this modern oil technology came about, so
    I don't think it will make the blindest bit of difference. Besides, the
    bike cost me 20 quid 3 years ago and is run on a tight budget. Bikes
    that are higher revving, more stressed, tuned to the nuts and running
    wet clutches deserve a bike specific oil.
    You run bikes that were designed in the same era as my Honda. I wouldn't
    dream of putting Castrol GTX in my 9R when I can buy 5L of bike specific
    Motul semi-synth and the filters for less money.
    Maybe Steve will understand this analogy. You buy all the very best in
    hi-fi gear available, the tuner deck, amps, cd player etc etc, then run
    it all through a set of substandard cheaper speakers. What do you expect
    it to sound like?
    As the old hi-fi saying goes "you put shite in, you get shite out".
    It's like buying a Gixxer thou and sticking Michelin Macadams on it
    because you can save a tenner a pair, then moaning cos it won't go round
    corners and you're falling off all over the place.
    Lozzo, Oct 12, 2004
