Which 125 Advise
Discussion in 'UK Motorcycles' started by Glenn Clark, Sep 6, 2007.
  1. Glenn Clark
    Glenn Clark Guest
    Hi all
    My wife has just passed her cbt and want's to get a 125 for work. She found
    the cg125 a bit heavy with its centre stand so is looking for something
    similar with a side stand.
    Can anyone suggest anything
    Cheers
  2. Glenn Clark
    <boggle>
    Doesn't the CG come with a side stand?
    Centre standing any bike is more of a matter of technique than grunt,
    however - although there's a couple of notable exceptions that spring
    to mind.
    Obviously, any of the little Japanese 125s that do have a side stand.
    However - if she isn't strong enough to put a CG on a centre stand,
    she isn't strong enough to pick it up when she drops it. I'd
    therefore suggest she sticks to a skateboard or a Ford Ka.
    Pip, Sep 6, 2007
  3. Glenn Clark
    Eddie Guest
    Not if IIRC. It's so easy to put on the centre stand, it doesn't seem
    worth it.
    If she's done her CBT, she should have been shown the correct technique;
    it's down to using your weight correctly, and practising the technique
    until you get the knack.
    Eddie, Sep 6, 2007
  4. Glenn Clark
    fudgemonkey Guest
    MMMMmmmmm lighter than a CG125, ever thought about a monkey bike?
    I'd stick with the CG, they get a good write up as being bullet proof
    and cheap as chips to run.
    The centre stand issue is all about technique and not strength.
    fudgemonkey, Sep 6, 2007
  5. Glenn Clark
    Pete Fisher Guest
    Can a side stand be retro-fitted? SWMBO found her first Yammy 100 a bit
    tricky, but there was a bolt on side stand available for those.
    Some centre stands are better designed than others. She could manage the
    one on the CB250 'Nighthawk', although TBF she usually used the side
    stand on that.
    | Pete Fisher at Home: |
    Pete Fisher, Sep 6, 2007
  6. Glenn Clark
    Derek Turner Guest
    Derek Turner, Sep 6, 2007
  7. Glenn Clark
    not IIRC.
    They are amazingly easy to put on the centre stand though - someone
    just needs to show this bloke's wife how to do it - it's not to do
    with strength.
    darsy, Sep 6, 2007
  8. Glenn Clark
    fudgemonkey Guest
    Yeah I saw that one too, how can you drag out a sidestand manoeuvre
    that long.
    Can't we just go round to Glens house and video his missus wrestling
    with a CG125 and put that on Youtube instead?
    Flip with all this video stuff
    1 - stand at side of bike, facing in same direction as
    2 - LH on the bars
    3 - RH on frame (palm facing behind you)
    4 - R boot on stand
    5 - Bendy knees
    6 - Lean back (and up a bit) gently by straightening legs
    If this fails take the stand off and just lean the bike against the wall
    in a Cafe racer stylie.
  9. Glenn Clark
    Steve Parry Guest
    In
    I'm fairly sure they have the same rest mounting as the CB125S had and they
    had a side stand so one could indeed be retrofitted.
    But honestly of she's taught how to put it on the stand properly it is
    really easy
    Steve Parry, Sep 6, 2007
  10. Glenn Clark
    Pete Fisher Guest
    I take your point (and Darsy's) but...
    <Looks round to make sure SWMBO is not in evidence>
    It's a machine innit? She is the most technophobic person I have ever
    met. TBF if she had ridden it more often I am sure she would have got
    the knack eventually. She is OK with karabiners and the like that she
    has been using for years but new gadgets take getting used to. As to PCs
    - don't ask.
    Before Lady Nina pipes up, this is not a gender thing, but a left/right
    side brain thing OK?
  11. Glenn Clark
    dog Guest
    best you just stop right there before you embarrass yourself.
    dog, Sep 6, 2007
  12. Glenn Clark
    Pete Fisher Guest
    No, you've whooshed me there.
    Incorrect reference to the right/left hand brain stuff perhaps? By all
    means enlighten me. Just trying to avoid being accused of a sweeping
    statement, "females don't understand machines", attitude. But, heh this
    is UKRM, I should know better.
  13. Glenn Clark
    dog Guest
    you were about to say something like "people who think with the left hand
    side of their brain have difficulty getting a cg125 onto the centre stand"
    weren't you?
    dog, Sep 6, 2007
  14. Glenn Clark
    Of course they would. They have to use their right foot and right
    hand to get it up, right?
    Pip, Sep 6, 2007
  15. Glenn Clark
    You may RC, but I can tell you that the Brazilian model (f'naar) does
    indeed have a side stand as well as a centre stand.
    Pip, Sep 6, 2007
  16. Glenn Clark
    Beav Guest
    Aren't they the same thing?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 6, 2007
  17. Glenn Clark
    dog Guest
    i suppose that's one way of looking at it.
    dog, Sep 6, 2007
  18. Glenn Clark
    Lady Nina Guest
    If someone shows her the technique it is easy. I found it a pig at
    first but you get used to it and then get a bigger bike.
    Practice.
    Lady Nina, Sep 6, 2007
  19. Glenn Clark
    cat Guest
    The POS125 I did my cbt on was a simple sidestand affair but I certainly
    did struggle with the GS500 being a bit on the "not bloody light side"
    My Instructor cured my lack of technique with a simple "ride it down
    there[1] and pop it on the centre stand"
    What took somewhat longer to cure was getting it back OFF! I'm 9st and
    couldn't seem to get enough weight behind the thing. We left it on the
    side stand for my test. I'm happily chucking my er-5 on and off its centre
    stand now and can confirm that even horribly skinny girls can do it with
    practise because the engineering chaps seem to have made sure it's more
    about levers than grunt.
    Cat
    [1] Right next to the BMW the two pretty city boys had just got out of.
    cat, Sep 6, 2007
  20. Glenn Clark
    Lady Nina Guest
    I know where she lives :)
    Hang on, you've met me.
    <clutches copy of 'The female Brain' - Louann Brizendine> [1]
    Really? Do go on
    <passes keys to JCB>
    [1] As opposed to an actual brain - that one was male.
