When to remap the ECU?
Discussion in 'Australian Motorcycles' started by Idej Adoy, Oct 21, 2003.
  1. Idej Adoy
    Idej Adoy Guest
    howdy,
    I've had my bikes exhaust debaffled and have installed a K&N filter and
    open airbox top. I keep hearing conflicting suggestions on weather I should
    now have my ECU re-mapped due to a risk of running lean.
    a) Should those changes warrant an ECU re-maaping?
    b) Is there a low cost test to determine weather I need my bikes ECU
    re-mapped?
    cheers
    Idej
  2. Idej Adoy
    John Littler Guest
    Yes
    Yes
    JL
    John Littler, Oct 21, 2003
  3. Idej Adoy
    alx Guest
    ditto what the man sayz.
    What bike is this for?
    alx, Oct 21, 2003
  4. Idej Adoy
    adam_c Guest
    You can get those spark plug extensions that have an opaque window in them.
    Depending on the colour of the spark, I believe it tells you if your bike is
    running lean or not. Obviously this can only be measured when the bike is
    not under load as you need to be standing down near the engine to observe
    this happening.
    Unfortunately this means that whilst your mixture may be good while the bike
    isn't under load, the conditions may change whilst it is, but you won't
    know.
    Thoughts anyone?
    Adam
    adam_c, Oct 21, 2003
  5. Idej Adoy
    FuTAnT Guest
    If you've spent the money already, spend a little more and get yourself a
    power commander and a good remap. You won't know yourself after it.
    Properly done they help an absolute shitload, not only with power/torque
    but also driveability, smoothness and fuel range, especially in the city
    riding modes.
    Cam
    '00 ZX6R
    FuTAnT, Oct 22, 2003
  6. Idej Adoy
    Idej Adoy Guest
    thanks all. the bike is 2001 900SS i.e
    Idej Adoy, Oct 22, 2003
  7. Idej Adoy
    John Littler Guest
    Called Colourtune and yes they can be a good way to ensure a good
    mixture on carbed vehicles
    JL
    John Littler, Oct 23, 2003
  8. Idej Adoy
    John Littler Guest
    Alright, I'll be helpful instead of mean:
    If you change the amount of air that the engine can flow it will
    change the fuel mixture (air /fuel ratio), hence you need to readjust
    the fuel flow - on a carbed bike you would rejet, on an efi you need
    to remap the settings (in the absence of a closed loop system via an
    O2(lambda) sensor)
    Most common way to do this is with an aftermarket module such as a
    power commander
    You can check the current fuel mixture status either with a lambda
    sensor in the header or most dyno tuners have tailpipe sniffers which
    do the same thing
    JL
