Wheelies are fun
Discussion in 'UK Motorcycles' started by Whinging Courier, Aug 22, 2006.
  1. In uk.rec.motorcycles, SD belched forth and ejected the following:
    They still do!
    I phoned them just now (well, a few hours ago) and it's 35 quid for a
    straight run and 120 for a run with a few tweaks and a custom map.
    I'll put the PC on and see how it goes but the bloke did much sucking of
    teeth and I could imagine him folding his arms, too ;-) but it might be
    worth a punt.
    Chicken ;-)
    Whinging Courier, Aug 25, 2006
    #81
  2. Whinging Courier
    They've got a Dynojet 250, so you'll get to see the wonders of the
    loop-back system. Fascinating it is.
    Oh, you do realise it'll **** your rear tyre good & proper, yes?
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Aug 25, 2006
    #82
  3. In uk.rec.motorcycles, Krusty belched forth and ejected the following:
    I can't wait...
    WTF's a loopback system?
    Err.. What, 'cos it'll have so much power that it'll get ripped to
    shreads as soon as I open the throttle?
    Whinging Courier, Aug 26, 2006
    #83
  4. Whinging Courier
    Dyno bod sits on bike & holds throttle at position indicated on dyno
    screen, starting at say 1/8th. The dyno modifies the drag on the
    roller, allowing the bike to slowly rev out to the limit. At every
    500rpm(ish) the dyno measures the CO then automatically writes the map
    setting for that particular RPM & throttle setting.
    Once it gets to max RPM, the dyno increases the roller drag to drop the
    bike's revs back down & the display prompts for the next throttle
    setting (1/4). The whole process then starts again. Repeat until all
    throttle positions have been covered.
    The result will be a map containing percentage adjustments for every
    throttle position at every RPM. These percentages change the amount of
    time the injectors are activated for, which is how the fueling's
    adjusted.
    The 'loopback' part refers to the dyno being able to adjust the bike's
    RPM by modifying the drag on the roller. At least that's the story I
    got from the hairy monsters at Dynotech.
    Err... not quite. More because the back will be strapped down hard
    forcing the soft tyre against the hard, abrasive roller. It'll get very
    squared off.
    This post was brought to you after less than one cup of coffee, so E&OE.
    Krusty
    Krusty, Aug 26, 2006
    #84
  5. In uk.rec.motorcycles, Krusty belched forth and ejected the following:
    Fascinating. I thought there was at least some technical expertise
    involved but actually, it's just a bloke caning **** out of my bike and
    does ****-all apart from importing a computer generated map.
    Hmm.. Not a huge problem. I was going to replace them soon anyway - Not
    because they're wearing out but because they don't get sticky unless
    driven to the ragged edge.
    I'm not sure Azara 3s will suit it but they get noticeably tacky after
    just a few short miles at a relatively slow (80mph or so) speed.
    I'm with you there, man. I'm more a tea drinker which reminds me..
    #85
