Wheel swap?
Discussion in 'Motorbike Technical Discussion' started by Shades, May 17, 2005.
  1. Shades
    Shades Guest
    '78 GL1000
    Is there a 16inch rear wheel that will bolt in place of the factory
    17inch wheel and still retaining my disk brake?
  2. "Shades" <shades_1970(at)netins(dot)net> wrote in
    message
    Why? That would change your entire suspension
    set-up. If you want to be able to put tubeless
    tires on find a set of Lester rims. E-bay has them
    on occasion...
    I ride a 79' GL1000 frankly can't imagine a good
    reason to go to a smaller rim...small tires don't
    make sense.
    Keith Schiffner
    RCOS #7
    Assistant to the Assistant Undersecretary of the
    Ministry of Silly Walks.
    "terrorist organization" is a redundancy
    Keith Schiffner, May 18, 2005
  3. Shades
    Shades Guest
    I run tubeless tires... I was looking at Tire selection.
    Shades, May 19, 2005
  4. "Shades" <shades_1970(at)netins(dot)net> wrote in
    message
    Buy a set of Lester rims. Best place to find them
    is Ebay. I run tubes in my ME880 and BT45 on my
    bike with no issues. There are a lot of good tires
    for the GL1000 out there. The Metzler gives good
    feedback, grip, wet traction and wear(last one
    gave me 18-20K miles) The BT45 does an excellent
    job even if I only get 8-10K miles per tire. Both
    are not very expensive...
    Front I'm running 100/90/19
    Back is a 120/90/17
    I've run 110 up front and 130 in the back...works
    good also.
    I've got excellent road to test on. US2/US89 Road
    to the Sun...MT200. All excellent roads to push
    the limits of tire and traction.
    Keith Schiffner, May 19, 2005
  5. Shades
    Shades Guest
    What about an 18 wheel?
  6. "Shades" <shades_1970(at)netins(dot)net> wrote in
    message
    Might not clear the swing arm. Krusty might
    know...but he's been quiet on this thread.
