Wheel Balancing stuff
Discussion in 'UK Motorcycles' started by Robbo, Jul 10, 2004.
  1. Robbo
    Robbo Guest
    Had the front wheel on the SOBeemer re-balanced this morning as I was
    getting significant tingles from the bars at certain speeds giving forrard
    and aft oscillation (Long technical word for shakes) at the fork lower
    sections, visible from on top at speeds on good surfaces.
    10 grams out was the verdict, rectified and all now fine at all speeds up to
    (ahem!) mph.
    What I was interested in is how much excess weight would have been off
    centre at the periphery, so to speak, at that 10 grams at given miles per
    hour?
    I know there's gotta be a formula somewhere for it.
    Anyone know?
    Robbo
    BMW K100 RS 1984
    BotaFOF #19. E.O.S.M 2001/2002/2003.
    B.O.S.M 2003.FURSWB#1 KotL..YTC449
    PM#7
    Robbo, Jul 10, 2004
  2. Robbo
    Robbo Guest
    Aha!
    You might be correct.
    Robbo
    BMW K100 RS 1984
    PM#7
    Robbo, Jul 10, 2004
  3. Robbo
    Euain Guest
    Hmmm.. if you're going to get fussy - weight is a force.. surely you
    meant forces and not weights... =)
    Anyway - the formula is Force = ma = mrww - where m is the mass, r is
    the radius, and w is the angular velocity (2 x pi x frequency). Just
    get everything into SI units and you're sorted.
    Euain
    Euain, Jul 10, 2004
