What's this switch for ?
Discussion in 'UK Motorcycles' started by Ian, Jan 18, 2004.
  1. Ian
    Ian Guest
    Treated myself to an N reg 900 Diversion yesterday. I've just noticed a
    small rocker type switch on the nearside in line with the keyhole to take
    the seat off. The setting are 1-0-2. Anyone know what it's for ?
    TIA
    Ian
    Ian, Jan 18, 2004
  2. Ian
    Sorby Guest
    That's your Nitrous-Oxide boost setting.
    Sorby, Jan 18, 2004
  3. Definitely aftermarket because mine never had it.
    Heated grips?
    The Older Gentleman, Jan 18, 2004
  4. Ian
    jsp Guest
    Forwards is seat eject.
    Backwards leaves and oil slick.
    John
    SV650
    Black it is
    and naked
    jsp, Jan 18, 2004
  5. Ian
    flashgorman Guest
    Blandness setting. Leave it on 2.
    flashgorman, Jan 19, 2004
  6. Ian
    Cab Guest
    On Sun, 18 Jan 2004 22:11:25 +0000,
    (The Older Gentleman) bored us
    all completely to death with wittery prose along the lines of:
    AONTL on both counts.
    Cab, Jan 19, 2004
  7. Ian
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, flashgorman
    "This one goes up to 11!"
    Nigel Eaton, Jan 19, 2004
  8. Ian
    Whilst I will concede that in general terms you are correct, I should
    like to point out that this is a Diversion. Accordingly, the
    blandness scale is annotated in Roman numerals, so what you are
    reading as 11 is in fact II. As high as it will go, granted.
    However, if you look at the corresponding control on a VFR800 ...
    Pip, Jan 19, 2004
