What's that rattling noise?
Discussion in 'UK Motorcycles' started by porl, Aug 31, 2005.
  1. porl
    porl Guest
    No, seriously. Coming back on the R1 I could hear a rattling noise emanating
    from below. In synch with the engine but more rattle-y coming from roughly
    where I'd imagine the camchain to be. Bearing in mind it's got about 1700 km
    on the clock what could it be?
    porl, Aug 31, 2005
  2. porl
    the camchain?
    darsy, Aug 31, 2005
  3. porl
    Paul - xxx Guest
    porl came up with the following;:
    The camchain?
    Paul - xxx, Aug 31, 2005
  4. porl
    porl Guest
    Why would a nearly new camchain rattle? I'm not saying it wouldn't, just
    don't know enough about them and I want to go back to the dealer pretending
    I know something about it.
    porl, Aug 31, 2005
  5. porl
    Steve Parry Guest
    duff tensioner?
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Aug 31, 2005
  6. porl
    Spike Guest
    Does the R1 have EXUP valves?...I assume so... If so, could be seizing/servo
    cables knackered in some way.... If so, its a rather quick and cheap fix to
    get it stripped and lubed, and a very expensive job if its left and the
    servo motors burn out.
    This is what happened to my litre fazer, and it cost £400 in parts alone :-(
    But in the best traditions of UKRM, Im probably fucking wrong...
    Spike, Aug 31, 2005
  7. porl
    Ginge Guest
    It could be the camchain, but equally it might just be that the valve
    clearances need doing as they've opened up a bit too much.
    Ginge, Aug 31, 2005
  8. porl
    I had a rattle associated with the EXUP-equivalent on my 'blade - it
    was rattly OK, but not even close to being "in synch(sic) with the
    engine".
    darsy, Aug 31, 2005
  9. porl
    porl Guest
    Yeah. I'll add it to my list of scary things that can go wrong.
    porl, Aug 31, 2005
  10. porl
    porl Guest
    porl, Aug 31, 2005
  11. porl
    porl Guest
    They'd have to REALLY need doing to make this loud a rattle. Almost
    cartoonesque characatured clearances such as you might find on...oh forget
    it, I can't be bothered.
    porl, Aug 31, 2005
  12. porl
    porl Guest
    This is why I never buy secondhand bikes goddamit.
    porl, Aug 31, 2005
  13. porl
  14. porl
    porl Guest
    porl, Aug 31, 2005
  15. porl
    Cane Guest
    Your endcan is fucked son.
    Cane, Aug 31, 2005
  16. porl
    Cane Guest
    I'd rather get MRSA..
    Cane, Aug 31, 2005
  17. porl
    Neil Guest
    Try checking all screws around the engine and carbs are tightened, sometimes
    that'll create a "Death rattle".
    I can't believe manufacturers went back to using camchains after the
    resounding success of the cam gear train..
    Neil
    Neil, Aug 31, 2005
  18. porl wrote
    If you could post a link to a sound file it would be very helpful.
    steve auvache, Aug 31, 2005
  19. porl
    Ben Blaney Guest
    Your imagination?
    A cruel practical joke?
    The onset of Alzheimer's?
    A Rope-esque fabrication in order to start a new thread?
    Ben Blaney, Aug 31, 2005
  20. porl
    Cab Guest
    By the sounds of it, you should never buy new bikes too!
    Cab, Aug 31, 2005
