What to do? -Tarmac surfing repair
Discussion in 'UK Motorcycles' started by JohnH, May 1, 2004.
  1. JohnH
    JohnH Guest
    Had a tarmac surfing experience on the m25 last week. Jeep in front
    slammed on his brakes, just got the bike to his right but left shin
    caught his rear bumper (thank **** for daytona's shin protection - no
    broken bones), bike flipped over onto its right side and started
    skidding, roughly 20 mph.
    Anyway fazer needs new right hand mirror + right side engine casing
    cover thing (bad graze leaking some oil) + some glue for the faring
    piece that got broken off, also need to bend the silencer hanger into
    shape so can refit the exhaust. For some reason the clocks seem to be
    positioned a little more to the right than usual, havent checked why
    though.
    Friend reckons i should get it rideable, and take it to a dealers to see
    if the frame is bent (main dealer is local). Any ideas how much this
    would cost? Also if it is bent (looks fine to my uneducated eye) is it
    possible to get it straightenened and how much for that? (presume a bent
    frame is an instance MOT failure).
    JohnH, May 1, 2004
  2. JohnH
    A.Lee Guest
    I had a GS650 done about 10 years ago for around £50, so probably £100
    ish now.This was a steel frame, which can be bent back straight.If it is
    an ally frame,and it is bent, then I think it is stuffed - you cant bend
    aluminium much without it breaking,or severely reducing its strength.
    It will only fail the MOT if they check wheel alignment, which IME, few
    do.(it sounds if anything, that your frame will be OK, though it may be
    wise to get it checked out).
    Alan.
    A.Lee, May 1, 2004
  3. JohnH
    I'd be surprised if the frame is bent as the bike didn't really hit
    anything immovable. It sounds like it just toppled over and slid down
    the road. The other damage appears to be standard slide down the road
    stuff.
    The clocks are probably out of line because the their mounting brackets
    have become pushed over by the movement of the top fairing.
    Personally, I probably wouldn't even have it checked.
    I didn't in similar circumstances when I outbraked myself, riding a steel
    framed bike, on the loose chippings approaching a roundabout. Managed to
    bend a fork leg by jamming the bike under a German girls car. Very nice
    about it she was too.
    sweller, May 1, 2004
  4. JohnH
    JohnH wrote in
    an MOT costs 15 quid and may highlight something you have missed
    wessie, May 1, 2004
  5. What to do? Learn the lesson, don't ride so f*cking close, and if you
    must then make sure you've got a way out. It's called the self-
    preservation society!
    Dave Remove my gerbil for email replies.
    Bike's are bosh, PC's are pointless, and the 1990's are nuts!
    Bikes are great, PCs are super, and the 1990s are the time to be!
    Save the apostrophe! Get 'em right! If in doubt, leave 'em out!!
    Dave Swindell, May 2, 2004
  6. JohnH
    JohnH Guest
    I know I know, thats the way i "normally" ride, just for some bolloxy
    reason i happened to be on the wrong side this time
    JohnH, May 2, 2004
  7. JohnH
    Zymurgy Guest
    JohnH wrote
    I've got a fazer mirror [1]. I'm not sure if they're handed, but i'll
    check if it's a RHS.
    Cheers,
    Paul.
    [1] Selling some bits for a mate ;)
    Zymurgy, May 2, 2004
  8. JohnH
    JohnH Guest
    It's a 98 old model fazer, i think the post 2000 ones have long spindly
    things. Just looked at the broken one, it certainly looks right handed
    so doubt a lefty will do.
    Dont happen to have a right hand engine casing (the front bit) do you?
    JohnH, May 2, 2004
  9. JohnH
    Zymurgy Guest
    JohnH wrote
    Yep, this is pre 2000. I will dig it out of the bits box in the garage
    tonight.
    Nope, but I have a brand new unused black ART can that will fit it.
    It has a collector pipe for a thundercat though. Same rear box, but
    will need a new connector pipe thingy.
    Start your bidding ;-)
    Cheers,
    Paul.
    Zymurgy, May 4, 2004
  10. JohnH
    JohnH Guest
    Ok cheers.
    Sorry dont want a can at the moment.
    If that mirror is a right handed one then i'll take it off you, doesnt
    have to be perfect, just not broken.
    My email is remove the letters in caps.
    JohnH, May 4, 2004
  11. JohnH
    Zymurgy Guest
    JohnH wrote
    Heh, sods law would predict that this looks like a lefty.
    Let me know when you chuck it down the left side :)
    Paul.
    Zymurgy, May 5, 2004
  12. JohnH
    JohnH Guest
    Oh well, thanks for digging it out anyway.
    Yeah will do, hopefully get rid of the bike before then!
    JohnH, May 5, 2004
  13. JohnH
    Zymurgy Guest
    JohnH wrote
    Well, now it's out. P/N 02*0087 TP-RT 5015
    Does that help ..
    P.
    Zymurgy, May 6, 2004
