what does engine oil taste like (or: Leaky 2: This Time it's Coolant)
Discussion in 'UK Motorcycles' started by darsy, Sep 22, 2004.
  1. darsy
    a bit of a steamy problem with the 7R yesterday[1], followed by actual
    observation of stuff dripping from the bellypan - looks suspiciously
    clear to be engine oil, I think, and stick my finger in it.
    Well, it's a bit sticky, but nothing like as sticky as I'd expect
    engine oil to be - so I tasted it - kinda sweet, pretty much as I'd
    expect a combination of water and anti-freeze to be.
    Question, as a sanity check, engine oil: does that also taste sweet?
    I'm not ruling out the possibility it's leaking *both* oil and coolant,
    but it's definitely leaking coolant because there was **** all in the
    reservoir when I got home, and filling it up again led to a big puddle
    on the garage floor an hour or so later.
    I've no need to actually use the thing for a while, so I guess it's
    "strip off the bodywork and have a look" time at the weekend.
    d.
    [1] got stuck[2] in a police-roadblock-generated[3] jam yesterday, the
    bike overheated, and when it got up towards the red, instead of the fan
    coming on, something audibly went "pop" and a find my head surrounded
    by a cloud of steam.
    [2] narrow two-lane-each-side dual carriageway, clogged with lorries,
    no room down either side or the middle.
    [3] they'd helpfully sealed off Meridien Way near the Coke factory, and
    were diverting all the Enfield/Chingford bound traffic onto the North
    Circular @ Edmonton Green.
    darsy, Sep 22, 2004
  2. darsy
    flashgorman Guest
    You need to drink at least a litre of it. If you die - its antifreeze. If
    your joints stop creaking - its oil.
    flashgorman, Sep 22, 2004
  3. darsy
    I'll give it a go, ta.
    darsy, Sep 22, 2004
  4. darsy
    flashgorman Guest
    Don't mention it. It's nice to see 16century diagnostic methods still in
    use. If you tasting of the patients fluid reveals an inbalance in the
    humours you should should consider the use of leeches.
  5. darsy
    Catman Guest
    IME no, sort of metallic.
    www.cuore-sportivo.co.uk
    Catman, Sep 22, 2004
  6. darsy
    platypus, Sep 22, 2004
  7. darsy
    Mike Guest
    Leeches are all imperial. You'd want the metric adaptor.
    Mike, Sep 22, 2004
  8. Modern Antifreeze is very bitter. Old fashioned antifreeze is very
    sweet, sort of Austrian Dessert wine sweet.
    Engine oil is, well, oily. I dont know how to describe the taste,
    other than it tastes like engine oil.
    ColonelTupperware
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/
    UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Sep 22, 2004
  9. darsy
    TMack Guest
    Make sure it isn't brake fluid dripping down from elsewhere - some types
    also taste sweet.
    Tony
    TMack, Sep 22, 2004
  10. darsy
    Steve Parry Guest
    <snip>
    It's tom cat piss
    hth?
    Steve Parry
    K100RS SE
    F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Sep 22, 2004
  11. darsy
    ....as they dissolve your tongue.
    ogden, Sep 22, 2004
  12. darsy
    Why would you expect a lubricant to be sticky?
    ogden, Sep 22, 2004
  13. darsy
    Owen Guest
    snip
    Its carcenagenic, don't do it again... ever... at all...
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Sep 23, 2004
  14. darsy
    SP Guest
    1) Thermostat buggered, preventing the coolant from running around the
    system as it should (this problem also means the fan won't kick in when
    it should).
    2) Cylinder Head Gasket foobarred. Strangely enough, this also means
    that the fan won't kick in when it should.
    Both symptoms will provide you with a nice puddle on the floor as the
    coolant mixture is forced out.
    Why not do a taste test yourself to find out?
    If it's oil & coolant, then the worst case scenario would be the head
    gasket. But that doesn't explain the puddle on the floor after
    refilling when the bike was laid up later on. You haven't taken any
    pipes off the coolant system at all recently, have you?
    Looks that way. Have fun.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Sep 25, 2004
