what does compression ratio mean?
Discussion in 'Classic Motorbikes' started by jd.holt, Dec 20, 2003.
  1. jd.holt
    jd.holt Guest
    I was under the impression that since the stated compression ratio for the
    bantam was 10:1 then I should be able to get 10 bar compression measured on
    a gauge. Is that right?
    I get a good 7 bar that seems quite solid. It is a cheapo colortune gauge
    but it shouldn't be hugely out I don't think. Could low compression be the
    reason it is difficult to start? Good spark, carburettor seems ok but still
    very temperamental.
    Thanks
  2. Compression ratios on 2-strokes are notoriously hard to measure, and I
    think I remember reading something to the effect that you'll never get a
    high reading anyway because of ports, something, I dunno.
    Same article said that a measured 7-8.5psi was about right, so yours
    sounds OK on that basis. FWIW 10:1 on a Bantam sounds unfeasibly high to
    me.
    Remember, anyway, that when checking CR you kick several times (or spin
    the starter) and do so with the throttle held wide open.
    The Older Gentleman, Dec 20, 2003
  3. jd.holt
    Mark Olson Guest
    I would expect the peak pressure developed to be lower for a 2-stroke vs.
    a 4-stroke, with the same ratio of swept volume to combustion chamber
    volume.
    Mark Olson, Dec 20, 2003
  4. jd.holt
    The Older Gentleman said...
    Compression and compression ratios are very different things.
    Compression is measured in Psi, or bar. Compression ratios are
    determined by the swept volume of the cylinder being worked as a ratio
    against the volume of the combustion chamber with piston at TDC.
    By their nature, 2-strokes do have considerably lower CR than 4-strokes.
    If you subjected any stroker to a CR even approaching 12:1 it would be
    self detonating all over the place and would melt the pistons in next to
    no time.
    You're right about 2-stroke compression being hard to measure, porting
    tends to screw things up by leaving bloody great holes in the sides of
    the cylinder wall for the compressed gases to escape through.
    Lozzo, Dec 20, 2003
  5. Listen to this, kiddies, because this is a man who owned RDs.....
  6. jd.holt
    *owned* being the operative word
    Lozzo, Dec 20, 2003
  7. jd.holt
    Geoff Berrow Guest
    <curious>
    Isn't the ratio measured from the point at which the ports are closed?
    </curious>
    Geoff Berrow, Dec 20, 2003
  8. jd.holt
    Geoff Berrow said...
    Not the way it was explained to me, but I may well be wrong, it has been
    known before.
    Lozzo, Dec 20, 2003
  9. out of interest, I recently did a compression test on the (now-removed) V8
    in the Lard Rover. half-way through, I remembered the thing about open
    throttle, so tried the next pot with throttle open and with throttle closed.
    made about 0.1 bar difference in about 8 bar.
    Austin Shackles, Dec 20, 2003
  10. jd.holt
    Buzby Guest
    It's a Bantam. They all do that Sir. Then they catch fire. JDAMHIK.
    Buzby
    Buzby, Dec 21, 2003
  11. jd.holt
    wayne Guest
    Oi! :)
    wayne, Dec 21, 2003
  12. jd.holt
    R L Driver Guest
    The compression ratio is a mathematical formula, stroke plus combustion
    chamber volume over combestion chamber volume . So for a 500 with 100 cc
    combustion chamber you would get 500+100/ 100 = 6:1
    In the real world of valve overlaps and fucking great holes in the barrel(
    like ports) the results at hand cranking speeds are never going to be
    anything like the theoretical levels.
    If your bantam wont start and its coil ignition , I would say crankase oil
    seals they love to leak air in and weaken the mixture.
    Steve the grease
    R L Driver, Dec 21, 2003
  13. jd.holt
    Rick Maninov Guest
    Yep a ratio of the gas volume in the cylinder at BDC to the volume at TDC,
    but in banties, I think the BDC volume in that equation is taken from the
    point on the stroke where the transit port closes.
    10:1 sounds a bit high for a bantie though.
    I liked your guess at crankcase seals.
    A lot of us old neat-petrol sniffing 4 strokers forget the secondary
    compression in the crankcase on these 2 strokes.
    Another give away is it'll drink fuel and lack power when he gets it going
    if it's seals gone.
    Rick
    Rick Maninov, Dec 21, 2003
  14. coo. ello Wayne. didn't know you read this as well.
    Austin Shackles, Dec 21, 2003
  15. jd.holt
    Mark Guest
    Later D14/B175 bantams are 10-1 compression ratio,according to the Official
    BSA manual.
    They should also all start within 3 kicks! If everything is set-up and
    working correctly.
    Ive got a D3 with Wipac flywheel magneto that always starts 3 kick.
    Try changing the Condenser to a Lucas DCB700 if its still using the original
    Wipac thing.
    Mark, Dec 21, 2003
  16. said:
    Not the same Wayne as collected those hood sticks from all those years
    ago? I still remember you owe me a pint! :)
    Simon Atkinson, Dec 22, 2003
