What does a trapped nerve feel like?
Discussion in 'UK Motorcycles' started by Ginge, Oct 9, 2004.
  1. Ginge
    Ginge Guest
    I'm getting stabbing pains in my shoulder when I raise my arm, I've just
    checked and there isnt' a knife stuck in it, so it must be something
    else.
    Pissing me off it is, ibuprofen time I think.
    Ginge, Oct 9, 2004
  2. Ginge
    Martian Guest
    Ginge wrote:
    [snip stabbing pains]>
    Yep, that sounds about right, my colleague in work has been off for the
    past three days with a stiff neck (couldn't get out of bed).
    TBH one of the most effective anti-inflammatory drugs available is still
    aspirin, just make sure that you have eaten before hand. Two aspirin
    and two paracetamol will sort you out, if they don't go and see the doc.
    Martin:
    VTR1000 Firestorm
    Martian, Oct 9, 2004
  3. Ginge
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Ginge
    You're not round at Nina's by any chance?
    Honda GL1000K2 Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Nigel Eaton, Oct 9, 2004
  4. Ginge
    Ginge Guest
    No, I'm not.
    Ginge, Oct 9, 2004
  5. Ginge
    Nigel Eaton Guest
    Hmm... It's not that then.
    You'd better get to hospital for a full CAT scan, cold enema and
    traction.
    Unless you want a second opinion?
    Dr. Nigel - Manufacturer of the "Champion-105" range of rearsets
  6. Ginge
    Or when it's painful enough to keep you awake for days, then that other
    anti-inflammatory works wonders. I can't remember what it's called,
    although I use it for my random trapped nerves. Pip will be along
    shortly to tell you what it's called.
    Muck, Oct 9, 2004
  7. Ginge
    Frozen shoulder sounds more likely. Do you get pins and needles in your
    fingertips?
    Have you been doing anything to bring this on?
    platypus, Oct 9, 2004
  8. Ginge
    Ginge Guest
    No more than the usual carpal tunnel twinges.
    Can't think of anything, I went to reach something off the shelf earlier
    and it went STABBY STABBY STAB! seems to hurt since then, but if I
    ignore the pain I've still got full movement.
    Hopefully it'll go away if I carry on ignoring it, if not I'll pretend
    it's French.
    Ginge, Oct 9, 2004
  9. Ginge
    Martian Guest
    Codeine, morphine, heroin etc....
    mmmmmmmmm
    Co-codamol = the best hangover cure
    Martin:
    VTR1000 Firestorm
  10. Ginge
    Is the pain in the muscle that lifts the arm?
    I've had trapped nerve stuff: I get a crawly feeling on the left upper back,
    occasionally tingly fingertips. I do a couple of neck exercises, relax, and
    it clears. No sharp pains.
    ....but for this pain, the drugs might work.
  11. Ginge
    Donegal Paul Guest
    "Muck" replied to Martian wrote:
    SNIP
    Do you mean Voltarol? Proper name Diclofenic.
    Donegal Paul
    Lambretta Li186 - crashed and bashed
    Vespa T5 Millenium - Wifey's (technically)
    www.thepilgrimssc.co.uk
    www.a4c.co.uk - What are YOU doing?
    www.ailishandcharlie.co.uk
    Donegal Paul, Oct 9, 2004
  12. Ginge
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Donegal Paul
    DON'T SAY THAT!
    The Drug That Must Not Be Named.
    Oh no, that's Voldemort. As you were, then.
  13. Ginge
    That's the one that usually sorts my nerve thingy. :)
    Muck, Oct 9, 2004
  14. Ginge
    Donegal Paul Guest
    "Nigel Eaton" said toDonegal Paul
    heh
    Donegal Paul
  15. Ginge
    Ginge Guest
    No, seems to be inside the shoulder itself.
    Ginge, Oct 9, 2004
  16. Ginge
    Gyp Guest
    Nor a fork. I've still got that.
    Gyp, Oct 9, 2004
  17. Ginge
    platypus, Oct 10, 2004
  18. Ginge
    Porl Guest
    Stop being such a pansy.
    Porl, Oct 10, 2004
  19. Ginge wrote
    I have heard of those symptoms.
    Hey ho.
    <fx: crosses Ginge off xmas card list.>
    steve auvache, Oct 10, 2004
  20. Ginge
    Donegal Paul says...
    Not so good if you have a morphine allergy, as I do. Voltarol fucked me
    right up for weeks after I dropped the shutter on my head.
    Lozzo, Oct 10, 2004
