What causes this odd wear pattern on a front tyre?
Discussion in 'UK Motorcycles' started by Mo, Sep 8, 2005.
  1. Mo
    Mo Guest
    I was wondering what was causing the leading edge of the tread block to
    wear less than the trailing edge, there's a 1mm step between each block
    The bikes a Deauville and the tyres are Michelin Macadam if that is
    part of the answer.
    Mo, Sep 8, 2005
  2. Mo wrote
    <waves>
    Oo please miss, me miss, I know the answer to this one.
    <squirms in seat>
    steve auvache
    750 VT Shadow (something for the weekend)
    Bindit 600 (was lost and now is found)
    GS500E (small but perfectly formed)
    mongvan (dehydrated)
    steve auvache, Sep 8, 2005
  3. Mo
    flash Guest
    Incorrect tyre pressures.
    flash, Sep 8, 2005
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Mo
    Have you got it bolted down to a concrete base?
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Sep 8, 2005
  5. Mo
    Braking. It's particularly noticeable on big trailee tyres where the
    larger gap between the tread blocks puts even more stress on the
    leading edge. Increasing the front tyre pressure helps apparently.
    Krusty, Sep 8, 2005
  6. Mo
    Eddie Guest
    Helps? Helps in what way? Helps to stop the front tyre working the way
    it was designed to do, perhaps?
    Eddie, Sep 8, 2005
  7. Mo
    tallbloke Guest
    Pressure too low?
    tallbloke, Sep 8, 2005
  8. Mo
    tallbloke Guest
    Or have you forgotton to restrain it with 5 tonne chain blocks?
  9. A plod biker once told me this was braking too hard.
    ALthough surely if you haven't fallen off you haven't braked too hard!
    danny_deever2000, Sep 8, 2005
  10. Mo
    flash Guest
    But do you know how many different answers will be given in total?
    flash, Sep 8, 2005
  11. Mo
    tallbloke Guest
    If the tyre is uffering so much deformation under braking at the correct
    pressure for the weight of the vehicle and the type of surface, it
    indicates that the tyre carcass isn't up to the job and should be replaced
    with something better.
    If a big trailee is doing this to a deep block tyre because it's getting
    hard road use, then the user should consider using more road orientated
    tyres or buying some better crash protection.
  12. Mo
    Ok, get rectangular type pencel eraser, stand it up on one of its ends
    on a bit of paper. Grip it with your fingers keeping it upright, press
    down and drag it across the surface of the paper its standing on.
    You'll notice that it flexes, and that the front edge tends to tuck
    under and wear more.
    That's what it happening on your tyre. The leading edges of the tread
    pattern tend to tuck under a tiny amount and wear at a faster rate than
    the rear edges when the brakes are applied.
    Muck, Sep 8, 2005
  13. Mo
    Steph Guest
    They're macadams, they come complete with their own concrete.
    Steph, Sep 8, 2005
  14. flash wrote
    My estimate, based upon current data, is 17 by close of play this
    evening.
    steve auvache
  15. Mo
    flash Guest
    I reckon there's only a few more to come, lets say ten in total plus a
    random reference to shaft drives.
    flash, Sep 8, 2005
  16. Mo
    Eddie Guest
    Bollocks, frankly.
    What about the case of a road bike, with the recommended tyres, inflated
    to the correct pressure?
    Perhaps I should phone up Bridgestone and tell them that their tyres
    aren't suitable for hard road use?
    Eddie, Sep 8, 2005
  17. Mo
    tallbloke emerged from their own little world to say
    I know a number of people who use Continental TKC80 on the R-GS. These are
    an off-road biased dual purpose tyre. In fact BMW offer them as OE on the
    Adventure. This type of wear is not uncommon but I've never heard anyone
    complain about getting into difficulty as a consequence. In fact, a number
    of people prefer the road handling of the TKC80s compared to other dual
    purpose tyres like Metzeler Tourance. Their only gripe is the rapid wear
    rate as they are a soft compound. From an economic point of view it makes
    little difference as TKC80s are pretty much half the price of longer
    lasting tyres.
    Manufacturers make road only tyres for large trailies e.g. the BT020 is an
    option. The general consensus is that these tyres don't offer much more, if
    any, extra grip. They are just more durable for those who do more miles on
    motorways. They cost more than dual purpose tyres so whether they are more
    economic is another issue.
    However, your contention that this type of wear presents a danger is
    bollocks IMHO.
    wessie, Sep 8, 2005
  18. Mo
    I haven't a clue - it's just what some people on the Tiger list have
    reported. I don't worry myself as I don't pay for tyres, so when it's
    'cupped' badly enough to cause vibration I just replace it.
    Krusty, Sep 8, 2005
  19. flash wrote
    You are forgetting the mention of floor pan and gear driven cams. Add
    those and do a bit of perming and 17 could easily be a gross
    underestimate.
    steve auvache
  20. Mo
    flash Guest
    Ah but *you're* forgetting that, after a while, two posters will drag the
    thread into a bitter and pointless argument over two opposing views.
    flash, Sep 8, 2005
