What a difference
Discussion in 'UK Motorcycles' started by Christofire, May 20, 2007.
  1. Christofire
    Christofire Guest
    a damper makes[1].
    Went out for a shortish bimble along some of the bumpiest roads I know
    around here and the bike felt completely untroubled.
    Normally there'd be a little flap on and off along most of it if you're
    on the power. It's something about the 10R that I almost like - it
    feels exciting, but there's the nagging thought that you're but a step
    away from a full on tankslapper.
    The damper, set to 1 (out of 8), kept it in check. The was the odd kick
    here and there, but it never got into a flap. I'm pretty chuffed as I
    don't like the way some dampers make the steering feel heavy, but even
    though it was a new toy I forgot about it when I was moving.
    It went on quite easily, with little fuss, head scratching or swearing.
    All in all, if it hadn't taken 6 weeks to get it'd be spot on.
    [1] http://www.flickr.com/photos/christofire/504713953/ - posted
    somewhere in the middle of another thread.
  2. Christofire
    Kiran Guest
    That is one ugly piece of kit ;-)
    Reminds me I wanted a replacement ohlins one for my GSXR, but not convinced
    it will make that much difference. I find the steering a bit slow at town
    speeds but I'm not sure if that's the damper or not.
    Kiran, May 20, 2007
  3. Christofire
    I put an Ohlins on my TLR because the stock one was a bit on the heavy
    side and the steering felt a bit dead, particularly in the wet. It
    does make a slight difference on slow corners at very low speed, but
    hasn't affected the rather heavy lifeless feel at any other speed.
    The trade-off is an occasional flap from the bars on bumpy roads if I
    don't bother to readjust it. I find the odd *slight* twitch adds to
    the fun. Having said that, I have had a couple of unexpected bigger
    flaps of the bars which were a little too exciting. It's odd, really.
    The bike feels pretty solid right up to the point where the bars flap;
    there's not a lot of warning.
    Pip Luscher, May 20, 2007
  4. Christofire
    Champ says...
    I think they look great.
    Lozzo
    Suzuki SV650 K3
    Suzuki GSX-R750L
    Yamaha 250 Flat-tracker
    I ride way too fast to worry about cholestorol.
    Lozzo, May 20, 2007
  5. Christofire
    There are standard style dampers which are progressive. Matris for
    instance.
    Hog, May 20, 2007
