What a difference...
Discussion in 'UK Motorcycles' started by Kevin Stone, Sep 21, 2005.
  1. Kevin Stone
    Kevin Stone Guest
    ....brakes that work make.
    I didn't have the time for a full strip of the Bandit's front brakes (as per
    previous posts the travel was notchy and was moving in chunks of travel -
    which was very odd, and tricky at low speed to control well).
    I've taken the callipers off and got some spray brake cleaner, pushed the
    pistons out a little and cleaned them the best I could. I was going to use
    petrol, but the manual says under no circumstances to use petrol, but, I've
    used petrol loads of times before (quite a few years ago now), so what's
    changed?
    And what a difference, you don't realise how bad [1] they were until they
    are better. They still aren't perfect yet, but they can now wait until I get
    some time.
    So sticky pistons it was then.
    [1] still pretty good really, but nothing in comparison to them now.
  2. Kevin Stone
    Steve Parry Guest
    Kevin Stone fumbled, fiddled and fingered:
    <SNIP>
    # a day makes.........
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Sep 21, 2005
  3. Petrol might cause the rubber seals to rot or swell. You're lucky you
    got away with it.
    Grimly Curmudgeon, Sep 21, 2005
