wet verse dry clutch
Discussion in 'Motorbike Technical Discussion' started by sg, Apr 29, 2004.
  1. sg
    sg Guest
    I am a new rider and I am considering a variety of bikes. Most have
    "wet" clutches. Some (Moto Guzzi) have dry. What are the advantages of
    one over the other. Also some have multiple plates and some have single.
    Same question.
    sg, Apr 29, 2004
  2. I'd just go with the bike you like most and don't worry about the type of
    clutch.
    SteveM
    Stephen Malbon, Apr 29, 2004
  3. sg
    Matt Whiting Guest
    Most cars and trucks use single plate dry clutches. They work well and
    last a long time. Most motorcycles and heavy equipment uses wet
    multi-plate clutches. They work well and last a long time. Most people
    consider wet clutches to be superior. If you look at heavy equipment
    makers, say John Deere for example, they use dry clutches and brakes on
    their low-end tractors and wet clutches and brakes on they high end
    equipment. Most dozers, etc. use wet clutches. Probably the only
    disadvantage to a wet clutch is the drag when the oil is cold making
    complete disengagement impossible.
    Multi-plate clutches advantage is getting more friction material in a
    smaller diameter package. I don't know of any other significant difference.
    Matt
    Matt Whiting, Apr 29, 2004
  4. sg
    Trey Guest
    The Dry clutch tends to be more "grabby" where the wet clutch has better
    articulation.
    I can ride my Suzuki with no trouble. I test road a Ducati, and stalled it a
    few times since the clutch was almost "off and on"
    Also, Air cooled are subject to debris, where the wet clutch is sealed in
    the oil, and can stay cleaner. However, oil on the clutch? kind of a
    contradiction, but I guess it works.
    Trey, Apr 30, 2004
  5. And the oil will move bits of friction material into the sump
    as well.
    Michael Sierchio, Apr 30, 2004
  6. sg
    Trey Guest
    In ether case, slipping the clutch is a bad thing. Most racers that do this
    are sponsored, so it doesn't matter. they will just put a new clutch in for
    each weekend.
    Trey, Apr 30, 2004
  7. Um, we may have different definitions of "bad" -- some clutches
    are designed to slip, a very nice thing when downshifting
    and braking, the rear wheel already being lightly loaded.
    And starting out in first? I generally find it necessary
    to slip the clutch -- though if you know of another technique I'd
    be happy to entertain it for a few milliseconds.
  8. sg
    Rob Munach Guest
    I just rev it and drop it into gear. I let my rear tire act as the clutch :>
    Rob Munach, Apr 30, 2004
  9. Yep, tires are easier to replace than clutches. ;-) Not any
    cheaper, though.
  10. sg
    Trey Guest
    The clutch, just like with the brakes, have a friction material, and a metal
    surface. Just like brakes, if they are not locked, there will be ware on the
    pads. Yes, a clutch is designed to allow for this. However, if it is abused,
    i.e., slipping the clutch while revving the engine for a long distance, will
    wear out the clutch.
    If you do enough high revving launches with the clutch slipping with a dry
    clutch, you will smell the clutch.
    Yes, the clutch is designed for this application, but it still wears out.
    Trey, Apr 30, 2004
