We're going to need a longer breaker bar.
Discussion in 'UK Motorcycles' started by Pete Fisher, Feb 5, 2010.
  1. Pete Fisher
    Pete Fisher Guest
    <BLOG>
    Not brass monkeys weather, so the rear wheel of the YZ250 came out today
    to be shod with something more suitable for tarmac.
    I knew the rear suspension was past its best from the ominous squeaking
    and slight clunking from the nether regions under provocation. Not much
    of an issue when bimbling along forest trails, but I don't think the
    NHCA scrutineer will be terribly impressed by the play in the linkage
    and possibly swinging arm bearings.
    The Clymer manual makes it sound so easy - "use a long extension and
    socket to loosen the relay arm pivot bolt nut". Hernia prevention 101
    and self preservation soon put a stop to that.
    Plusgas has been applied and it looks as if I may get to play with my
    rattle gun again.
    </BLOG>
    | Pete Fisher at Home: |
  2. Pete Fisher
    Nige Guest
    Same here, gotta get the crank nut off a landie 90 :(
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Feb 5, 2010
  3. Pete Fisher
    Pete Fisher Guest
    Left it to soak in Plusgas while I had a quick cobweb blow out in the
    MX5 and it finally shifted with my biggest breaker bar.
    I have never seen such utterly shagged bearings - ever. I can't remember
    finding needle rollers actually broken before. It's all shot. The shims
    on the swinging arm thrust bearings are rusted and cracked. I don't
    think the frog who had it before me knew what grease was.
    From a quick Google I can get a complete bearing and seals kit for it.
    but I think I'll let John at Revs put them in. I'm hoping he can also
    helicoil the chain adjuster thread that's fucked - or tap them both out
    to a bigger size. Otherwise I think I'll just knock the project on the
    head and do a break and Ebay job.
    | Visit my Home Page : http://www.flarefox.com/Lesbordes |
    | "Do not adjust your mind - there is a fault in the reality" |
  4. When I took the Gamma apart after seizing it in its first race at
    Westwood[1], then having it restart only to terminally die as I crossed
    the finish line, I didn't find _any_ rollers in the small-end bearing --
    just dust...
    [1] Having forgotten that a Suzuki two-stroke needs the clutch to be engaged
    to activate the oil-pump.
    Dr Ivan D. Reid, Feb 5, 2010
  5. Pete Fisher
    Should have bought a Yamaha with Autolube.
    A year or so ago stripped down my nephew's old Aprilia RS50 and found
    the cause of the bad rattle it had before it seized - there were only
    two complete needles left in the small end bearing. As he was skint and
    flogging the thing we did a cheap job of repairing it, which involved
    delving around in the crankcases with a magnet on a stick to fish the
    broken bits out of needle and cage, matching them all up to what was
    missing then putting a pattern barrel and piston on with a new small
    end bearing.
    It's still running ok cos one of the local scrotes has bought it and I
    see it nearly every day being ragged up the High Street. One of the
    things he was told was that he absolutely must run it on the best fully
    synth 2-stroke oil available, which is something my nephew had been
    told but ignored, hence the seizure and destroyed bearing.
    Lozzo, Feb 5, 2010
  6. Pete Fisher
    Pete Fisher Guest
    Better off with the right petroil mix. I've had catastrophically failed
    needle rollers inside a two stroke before - like the SWM at Cadwell on
    hill climb gearing.
    Not seen the like of these outside an engine though. So many of the
    buggers to replace as well, not like good old phosphor bronze bushed
    swinging arm bearings and twin shocks.
  7. Pete Fisher
    zymurgy Guest
    **** 1/2" drive stuff for that, i've gone up to 3/4" drive now. Now
    that's sexy tool porn ... ;)
    Paul.
    zymurgy, Feb 5, 2010
  8. Pete Fisher
    TMack Guest
    Replacing needle roller swinging arm bearings can be quite easy. I did the
    job on my semi-rat LS650, which had bearings like the ones that you found -
    rusted solid and completely fucked. I got the old bearings out by hammering
    an old, thin screwdriver between bearing casing and seating. The bearing
    casing is quite thin and distorts fairly easily, making it possible to
    deform the casing enough to loosen it and remove it. The damage done by the
    screwdriver to the seating for the bearing was minimal and as it only
    affected a very small area of the whole seating it wasn't going to be a
    problem. I then throughly cleaned the seating and smoothed down the scratch
    left by the screwdriver. then greased it lightly to assist the new bearing
    going in. Next step was to use a long threaded bar with suitable
    combinations of large washers and sockets to pull the new bearing into place
    by tightening down a nut on the threaded bar. The whole job took less than
    an hour to do both sides.
    TMack, Feb 6, 2010
  9. Pete Fisher
    I'm pretty boggled to see a post like this from you with no random
    swearing, you big cuntlyfile-watching pissflapping gash-faced minge
    shitter.
    darsy, Feb 6, 2010
  10. Pete Fisher
    Pete Fisher Guest
    In communiqué <hkj74o$1au$-september.org>, TMack
    Well I think I'll at least have a go at getting the remains of the old
    bearings out. Chatting to one or two others at the NHCA AGM today
    confirmed that your technique usually works OK.
    The latest problem is the rear tyre. I had an Avon AM23 club race
    130/650 x 18 that I decided was too big for the Morini, and Avon said
    would go on a 2.15 rim OK. The fitters can't get it to seat perfectly by
    one of the security bolts (which aren't really needed now anyway). It's
    currently got loads of gloop on the affected area and is sitting pumped
    up to UXB pressures in a warm place. It was creeping slowly out, but
    isn't anymore. Should have been less of a pikey and had the wheel
    rebuilt to wider and 17 inch while I was having the front done.
    Pete Fisher, Feb 6, 2010
