Well, the clutch is back in, but ...
Discussion in 'UK Motorcycles' started by SD, Feb 4, 2007.
  1. SD
    SD Guest
    .... still no joy on the snapped bolt. It's got a hole in it, and
    temporarily, the end of a drill bit.[2]
    Progress this weekend was hampered by the start of the Six Nations
    rugby, but, having assembled the clutch, and refitted the spring, it
    wouldn't go in.
    Now, you can't assemble a GL1500 clutch like a normal one - you have
    to mount all 19 (nineteen!?) plates between the clutch centre, and
    pressure plate, then fit the diaphragm spring, and circlip, then try
    to thread the clutch unit onto the splined shaft. Of course, there's
    no way of establishing the relationship of the splined shaft, to the
    cutouts on the clutch basket. This results in much swearing.
    Eventually, I assembled it on the shaft, tightened the lifter plate on
    loosely, then *carefully* removed it from the shaft, and fitted the
    spring. It then refitted with only minimal swearing.
    Washer on, threadlock on the centre shaft, and a restaked nut later,
    and all's hunky dory. The lifter plated seated nicely, and torqued
    down correctly onto the intact threads of the new pressure plate.
    A nice clean surface of the cover had a smidgen of blue hylomar
    applied, and then the fun of doing up the fourteen bolts that hold it
    in place could begin. There are 9 short bolts, five longer ones, and
    you can't see 8 of the holes they have to go into. Additionally, four
    of them have to hold hose clips. I used all three (1/2",3/8" and 1/4")
    drive sizes to do up the bolts, as clearance and reach were different
    on each on. Oh, and I used a ratchet spanner with a 3/8" drive
    attachment too. Great fun.
    So, that's done - even the slave cylinder is back on. Woohoo.
    More fun looms with the snapped alternator mounting bolt tomorrow
    evening, then I can check the cambelt for alignment once more[1], fill
    it with oil, and reassemble the twelvety-seven bits of bodywork that
    had to be removed.
    With luck it could be rolling before the weekend.
    [1] Question: how *exactly* do the "up" marks have to match? When the
    lhs one is bang on the money, together with the centre one, the rhs
    one is out by maybe 1/3 of a tooth's width. It's definitely not a
    whole tooth out, cos I've moved the belt on the pulley to check. Seems
    that the only method of adjusting is through tensioner tension,
    iyswim.
    [2] I presume going up in bit sizes will eventually work, yes? That
    cheap Ryobi cordless drill/driver is proving useful, after all.
    | ___ Salad Dodger
    |_\_____/_| ..87918../..23274.../..31893.
    SD, Feb 4, 2007
  2. SD
    Pete Fisher Guest
    I know nothing of multi-cylindered plumber's nightmares in this respect,
    but on a trusty single lunger like a Nordwest you can't be absolutely
    sure you are bang on the money until the belt tensioner is back in
    business. If all appears well, then it is still worth turning the motor
    over a few times and rechecking before lighting the blue touch paper.
    <This message is brought to you post bottle of a jolly acceptable
    'entre-de-mers' so typos may be numerous and significant>
    | Pete Fisher at Home: |
    Pete Fisher, Feb 4, 2007
  3. SD
    "deux"
    platypus
    "Merely corroborative detail, intended to
    give artistic verisimilitude to an otherwise
    bald and unconvincing narrative."
    platypus, Feb 5, 2007
  4. SD
    Pete Fisher Guest
    Quite so.
    Pete Fisher, Feb 5, 2007
  5. SD
    Mo Guest
    Typo corrected
    Mo, Feb 5, 2007
  6. SD
    SD Guest
    Now replaced with the end of a screwdriver. Arse.
    It will come out. I shall not be beaten.
    | ___ Salad Dodger
    SD, Feb 5, 2007
  7. SD
    You're telling us what, exactly, here?
    platypus
