in message ..net...[QUOTE] Simon Atkinson wibbled ... It's as simple as that? Is that method accurate then? Must be I[/QUOTE] guess, or you wouldn't do it :) This isn't quite the whole story. The above description is for what is termed "static wheel balancing" and stops the up and down movement. If wheels where infinitely thin this is all that would be required. The computerised wheel balancing machines dynamically balance the wheel. This also corrects for the difference in weight distribution across the width of the wheel which results in a side to side movement. A dynamically balanced wheel will by default be statically balanced. Small bike wheels and rears (IMO) don't really require dynamic balancing. I think bike tyre manufacturers recommend that wheels above a certain width are dynamically balanced. I don't have enough experienced of such matters to say if it can really make a difference and I often make do with static balancing myself (i.e. after the clueless numpties at the tyre fitting place have screwed up). HTH Jim
