Well, that's the wheel out...
Discussion in 'UK Motorcycles' started by Salad Dodger, Aug 29, 2003.
  1. Salad Dodger
    Salad Dodger Guest
    ....only took an hour. :(
    Two splits, and a big hole. No wonder the tyreweld struggled to retain
    pressure.
    I do hate replacing tyres early: this one's only done 9500 miles.
    Cush rubbers are totally fecked, too. Good job I've got some new ones.
    Right, now to find someone who has a Bridgestone 160/80H16 G702.
    | ___ Salad Dodger
    |/ \ GL1500SEV/CBR1100XXX/KH500A8/TS250C/exTS185C
    _/_____\_ ..57146../..13615.../..3157./.19406/.fecked.
    |_\_____/_| IMC#4 TPPFATUICG#7 YTC#4 DIAABTCOD#9 PM#5
    (>|_|_|<) BOTAFOT #70 two#11 Ignoramus #0001
    |__|_|__| BOTAFOF #09 IbW#0 & KotIbW# OSOS#07
    \ |^| / WG* BotTOS #6 GP#4 ANORAK#17
    \|^|/ 2003 RBR landmarks:81 points:1740 miles:6835
  2. Salad Dodger
    Don't forget the Ultraseal (1) this time. Really!!
    (1) Gixxer tested to 170+
    Hog, Aug 29, 2003
  3. Splits aren't "normal"; any chance of getting a freebie replacement
    from Bridgestone by claiming shoddy materials? Take JP with you...
    William Grainger, Aug 29, 2003
  4. Salad Dodger
    Salad Dodger Guest
    £142.15 !
    Fuckin' hellbeanz.
    | ___ Salad Dodger
  5. Salad Dodger said:
    http://www.fwr.co.uk/ might be cheaper.
    Simon Atkinson, Aug 29, 2003
  6. Salad Dodger
    Simon Atkinson fascinated us all by saying...
    I was in there today, they came up with the best price for the Avon
    AV45/46 STs now adorning my ZZR11. Shame the front wheel balancing is
    wrong, got a nasty hammering through the bars at anything over 100mph.
    Makes the mirrors blur badly, which isn't good for spotting approaching
    blue lights when 'making progress'. I'll be getting it sorted locally,
    first thing tomorrow, cba riding all the way through the West End to
    Kennington just for that.
    Lozzo, Aug 29, 2003
  7. Salad Dodger
    Ginge fascinated us all by saying...
    I like them already, and they aren't even scrubbed in properly yet. I'd
    like them even more if the balancing had been done right.
    Lozzo, Aug 29, 2003
  8. Lozzo said:
    They are good on price (usually). I must go down for a front for mine
    in the next week or two.
    That'a a bit naughty - still, we can all make the od mistake. You going
    to balance it youself to get it right? Only takes a minute or two.
  9. Salad Dodger
    Salad Dodger Guest
    I wish I could read: £132.81 fitted.
    Put the new cush rubbers in too.
    The old ones lifted out easily, the new ones needed persuading with a
    rubber mallet.
    All I need now are new gaskets to seal the silencers onto the
    collector box.
    | ___ Salad Dodger
    _/_____\_ ..58320../..13655.../..3157./.19406/.fecked.
    \|^|/ 2003 RBR landmarks:99 points:2100 miles:8000
  10. Salad Dodger
    I hadn't thought about doing it myself actually. I have all the required
    kit at work, so may do just that.
    Lozzo, Aug 29, 2003
  11. Lozzo said:
    Another convert to the Avon 45/46 way... Be interesting to see how long
    they last on your lardy old bus (assuming you keep it long enough).
  12. Bear said:
    Two stands and a spindle. Place the spndle through the wheel bearings
    and stand it on the stands. Gently spin the wheel and watch where it
    stops. If it 'rocks' to a halt then the wheel has stopped with the
    heaviest part at the lowest position. Stick a weight at the top and do
    it again until the wheel stops at any random position and not at the
    same place each time.
  13. Bear said:
    As accurate as the user! The more time you spend and the more careful
    you are to ensure that the stands are holding the wheel absolutely
    vertical etc, the more accurate it will be. Even not taking too much
    care gets it easily close enough for there to be no noticable vibration.
    It's the way I've done it for years and never had a wheel balance
    problem.
  14. Salad Dodger
    Ben Blaney Guest
    Well, they're not really tyre-fitters, they just do it if you ask
    nicely.
    They're an old-fashioned bike shop, oft-mentioned here (Swift
    Motorcycles of Laindon). Lovely blokes: got three 1950s Nortons that
    haven't moved in all the time I've been going there (10 years), and one
    has only two miles on the clock.
    Ben Blaney, Aug 29, 2003
  15. I've been using that method for years and found that when compared to
    a computerised balancing rig it's just as good.
    Top Tip: you can re-use stick-on wheel weights by glueing them on with
    silicone sealer.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Aug 29, 2003
  16. Grimly Curmudgeon said:
    How much does a tube of silicon cost? Compared to a load of weights for
    free if you pop into your local cage tyre palace and ask for some
    nicely?
    Simon Atkinson, Aug 30, 2003
  17. Well yes, but...
    a) I have silicone
    b) I have a load of used weights.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Aug 30, 2003
  18. Grimly Curmudgeon said:
    Are you from Scotland by any chance?
  19. Aye, laddie.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Aug 31, 2003
  20. Grimly Curmudgeon said:
    Just a wild guess... I must have got lucky.
    Top-tip no 23: Methodist church roof lead is the best for balancing
    cross-ply tyres. Lead from Elim Pentacostal for radials.
    Simon Atkinson, Aug 31, 2003
