Well... that was 'interesting'
Discussion in 'UK Motorcycles' started by deadmail, Sep 22, 2007.
  1. deadmail
    deadmail Guest
    So, picked up the outfit at about 10 this morning in sunny walsall.
    Within 50m I had to negotiate a junction. So I braked, the outfit
    veered to the other side of the road into the path of a van. Oh dear.
    Fortunately the van stopped and looked on amused at my expression of
    horror (since I'd frozen; my instinctive countersteer made things
    worse...) Oh well, only 110 miles to go.
    Within another coupla hundred metres I managed to mount the pavement
    with the sidecar... near a bus queue. Whoops. Still, it gave some
    people some exercise as they got the **** out of my way.
    After a little while it all sort of made a bit more sense. It weaves
    about a bit with a lot of bar juddering at sub-30mph speeds so I guess
    it needs a look at the tyre/steering damper (note, the tyre suggestion
    came from Pete Fisher; thanks)
    Once I got to the M6 it was OK except it was hard work to steer in a
    straight line, with a bit of camber it really pulls towards the gutter.
    More later.
    So then onto the M5 and getting a bit more comfortable. So, let's see
    how fast she goes... 80 was OK, it didn't really want to pull much more
    so I didn't push it. Leave that for another day.
    THe fucking surveillance cameras were clearly working; I saw a message
    "Debris in road, slow down". I thought this was a bit fucking personal.
    After a while cruising at 65-70 was comfortable (ignoring the steering
    input required) it was misfiring slightly, ignition thing I supposed;
    coil or something along those lines. Then came into traffic and ended
    up in the outside lane, overtaking a lorry... and it cut out on one or
    two cylinders. Arse. Came back on song soon enough though but not
    enough to avoid worrying me.
    Eventually get to the Cheltenham turn off and went to see Champ, Peter
    Fisher, Platy and Sweller at the hill climb. On my way there got the
    chair off the ground, accidentally. Nice.
    Pete was helpful pointing out "it's leaning towards the chair, not away.
    You'll need to fix that". Platy asked if the vendor was a large chap,
    he was; this explained the setup... Platy and Sweller sat on the bike
    and the suspension compressed looking approximately correct. Fiddling
    required.
    After that ended up back on the M5 and heading south.
    Journey home without incident, well excepting misfires (advice of all
    and sundry was condenser breaking down) and also running out of petrol.
    Fortunately I had reserve to rescue me.
    Final piece of stupidity was fucking about lifting the chair Make sure
    you're close to the centre of the road when you do this... if you aren't
    then you run the risk of drifting towards the gutter... and being unable
    to put it down!
    So, short version, in conclusion.
    1. Thanks to Pete and Platy for sundry advice.
    2. Thanks to Sweller for bringing the Guzzi; that bike looks better
    every time I see it.
    3. Chair's are perfectly safe as long as you don't get too cocky.
  2. deadmail
    MikeH Guest
    You got all uppity when somebody tried your chair out.
    MikeH, Sep 22, 2007
  3. deadmail
    muddy cat Guest
    I thought that was mandatory? everyone I've seen has done much popping,
    backfiring and making great clouds of smoke.
    muddy cat, Sep 22, 2007
  4. deadmail
    muddy cat Guest
    I must admit, I fancy an outfit too.
  5. deadmail
    I sat on it, didn't compress it enough, got Sweller to climb on the back,
    which made it compress enough to look like it wasn't actually leaning
    towards the chair. So, no.
    platypus, Sep 22, 2007
  6. deadmail
    You probably won't fit in the chair. I barely got in and out.
  7. deadmail
    Burnt, hold the suspension adjustments
    wessie, Sep 22, 2007
  8. deadmail
    deadmail Guest
    Don't take this badly. I wouldn't trust you not to abuse the poor
    thing.
  9. deadmail
    wrote in
    You sentimental old fool.
  10. deadmail
    Calm down. You can have a go on the Ural. It's inured to abuse.
    platypus, Sep 23, 2007
  11. deadmail
    deadmail Guest
    deadmail, Sep 23, 2007
  12. deadmail
    deadmail Guest
  13. deadmail
    Snowleopard Guest
    On Sat, 22 Sep 2007 22:18:59 +0100, said
    The experience appears to have completely fucked up your grammar,
    though.
    Snowleopard, Sep 23, 2007
  14. deadmail
    Don't listen to him. The fuzz has nothing to do with you - I'm simply
    trying to look like as big a **** as possible.
  15. deadmail
    deadmail Guest
    Hmm. You may well have a point.
  16. This is it, in a nutshell. Once you've learned the Black Art, they're
    easy, but if you try and show off and be a ****, you'll soon find out
    how unforgiving of error they are.
    The Older Gentleman, Sep 23, 2007
  17. deadmail
    <shrugs>
  18. deadmail
    Heh.. sounds like fun. :)
    Muck, Sep 23, 2007
  19. deadmail
    Bollocks.
    sweller, Sep 24, 2007
  20. deadmail
    I am a God - now supplicate before me.
