Well I have been 500 miles...
Discussion in 'UK Motorcycles' started by ginge, Apr 5, 2007.
  1. ginge
    ginge Guest
    No, not the proclaimers, the running in period. No more 4000 rev limit,
    thank ****.
    ginge, Apr 5, 2007
  2. ginge
    David Thomas Guest
    Good init? I am now on 750 miles so can go to 6000 revs... whoopee doo.
    I think it is 1000 miles before I can use the rest on the revs[1] on my
    bike, so should be there by Sunday.
    David
    [1] The other 4500, it red lines at 10,500
    David Thomas, Apr 5, 2007
  3. ginge
    Ben Guest
    420 here.
    But I thought "fuckit" and gave it some welly earlier.
    By god the horizon doesn't half come towards you quickly.
    First service is next Saturday when it should be nicely on 600 miles.
    Ben, Apr 5, 2007
  4. ginge
    David Thomas Guest
    Well I was tempted but to be honest I doubt the horizon would have come up
    any quicker... mines an ER-5.
    Still at least my first service is out of the way at 652 miles[1], so
    hopefully a clear run to 4000 miles now, fingers crossed.
    [1] That sounds real anal, I meant 600ish
  5. ginge
    Molly Guest
    Away you go young man.
    Molly, Apr 5, 2007
  6. ginge
    Molly Guest
    I subscribe to Champ's method. It works for me.
    Molly, Apr 5, 2007
  7. You only get one chance to run it in. Not so bad if you have the HOG
    approach. If the engines fucked by 10K who cares. I'll have sold it by 5K.
    eric the brave, Apr 6, 2007
  8. ginge
    Ben Guest
    After what happened to your GSXRs engine, I'm not sure it did work for
    you.
    Ben, Apr 6, 2007
  9. ginge
    Ben Guest
    No idea how fast I was going, when I'm doing that I don't tend to
    watch the speedo.
    Ben, Apr 6, 2007
  10. ginge
    Molly Guest
    That was a know fault. You Champ's method exposes known faults.
    Molly, Apr 6, 2007
  11. ginge
    Molly Guest
    "eric the brave" <""simonb_at_zapik_dot_co_dot_uk\"@foo.com (eric the
    brave)"> wrote in message
    I have read in quite a few places that Champ's (or more radical) does
    produce more power from an engine. The key, as Champ said, is to listen to
    what your engine is telling you. I know mine was a bit tight so I modified
    Champ's charter to suit.
    Molly, Apr 6, 2007
  12. ginge
    There is a huuuuge amount of bollocks spoken about the running in of
    engines. Most of it relates to a bygone era of design and material science.
    For instance an RD400 rebuild requires much more care than a new Gixxer
    thou.
    I think this guy talks sense: www.mototuneusa.com/break_in_secrets.htm
    and to the other **** ^^^ up there! I was referring to 50K and 100K miles
    and not many bikes ever get past 50k.
    Talking for more recent Beemers, nickasil liner types, I've seen the bores,
    pistons, cam and main bearing surfaces of careful aged riders Vs couriers. I
    thought the hard used engines looked fine. Thrashed from 500 miles, not
    lying in garages for months but serviced and oil changed on the dot.
    IMHO a K100/1100 engine, run in the right way, with decent oil/filter every
    5000 or so, it likely to last 500k with th odd clutch/sprag.
    Hog, Apr 6, 2007
  13. I still say you only have one chance to run it in properly. I can
    remember all this with Honda Fireblades. The quickly run in ones where
    fine till 10k then the power was normally less than a well one in one.
    Tightness of cam shaft bearings was the overriding difference in power
    output in most bikes. A factory tolerance problem.
    I quite agree with Champs article. However Champs write up mentions
    nothing of heat cycles. It's the heat cycles that bed an engine in. Too
    much heat too soon will cause the internals to be forced together too
    much and pre-mature wear will rake place. So it's a very fine line we
    are talking about here.
    As I said before, You only get one chance to run it in. It's like a
    interview. You only get one chance to get it right.
  14. There is a huge amount of bollocks talked about on the internet. Just
    because MotorMan wants to sell stuff he writes stuff. Just take a look
    at http://www.zx-10r.net/ if you want an example. I am a mechanical
    engineer by trade and qualifications, also a indentured Tool maker. So I
    do understand something about this.
    All I'm really saying is that "You only get one chance". You can run it
    in how you wish. As you've stated before, It won't be your problem anyway.
    Running in race bikes is different. You don't need to worry about longevity.
  15. ginge
    Ben Guest
    Personally, I reckon Kawasaki know best what the engine they designed
    requires as far as running in goes so I'll attempt to reasonably stick
    to it.
    Champ's recommendations aren't too different from Kawasaki's apart
    from the rev limits.
    Ben, Apr 6, 2007
  16. ginge
    Ben Guest
    That's pretty much exactly what the 10R manual says, apart from being
    4k for the first 400, then 6k to 600.
    Ben, Apr 6, 2007
  17. ginge
    I think these are pretty much within the spirit of what I said and what the
    article suggests. That first 500 miles is key.
    Hog, Apr 6, 2007
  18. ginge
    ginge Guest
    I don't rememebr reading anything about throttle use, but my take on
    every bikre has been 1/2 for the first couple of hundred miles, 3/4 for
    the next couple of hundred, and occasionally full after that... but
    always on a well warmed up engine.
    ginge, Apr 6, 2007
  19. ginge
    It's the slamming on the brakes and slowing right down for corners that gets
    me. I was nearly up his chuff at the TT.
    Trackday tuition, and lots of it.
    Hog, Apr 6, 2007
  20. ginge
    ginge Guest
    Except oddly I do find it comfortable.
    The main reason for buying it is that since the mallory trackday last
    year I've all too frequently found myself thrashing the tits off the
    ZRX, and I wanted something more sporty. I was going to go for a gixxer
    750 originally, but the 10R worked out to be as comfy, and a fair bit
    cheaper, so I figured why not.
    Don't regret it, the bike is great fun.
    ginge, Apr 6, 2007
