Welding question...
Discussion in 'UK Motorcycles' started by Nick, Dec 13, 2008.
  1. Nick
    Nick Guest
    A friend wants me to lower her bike but am concerned about the side stand
    then keeping the bike too upright. If I can't grind enough off the stop, can
    I cut the ( cast iron) leg and get it re-welded a bit shorter or does cast
    iron not weld ? Does anyone do steel / weldable side stands ? Centre stand
    is ? mild steel so assume that is OK to cut / weld up and re-paint ?
    Thanks,
    Nick
    Nick, Dec 13, 2008
  2. Nick
    Cast iron is notoriously hard to weld...
    Timo Geusch, Dec 13, 2008
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Nick
    Are you sure that the side stand is cast *iron*?
    Wicked Uncle Nigel, Dec 13, 2008
  4. Nick
    I don't know of any bike with a cast iron stand, cast steel maybe, but
    not iron.
    Lozzo, Dec 13, 2008
  5. Nick
    Nick Guest
    No - not sure - it looks "cast" so assumed it was "Cast Iron".
    Its definitely not welded up mild steel
    (Its a 2002 Fazer FZS600 Fox-Eye)
    Thanks,
    Nick
    Nick, Dec 13, 2008
  6. Nick
    It's cast steel
    Lozzo, Dec 13, 2008
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Thought so.
    So, over to this lot:
    Engineering types! What's the story on welding cast steel? It's the side
    stand on a motorbike that'll need shortening, so the foot wants cutting
    off and reattaching.
    I've seen it done on an old Kawasaki that I owned. How hard it is?
  8. Nick
    newshound Guest
    Personally (being a crap welder) I would cut off the foot, try to find a bit
    of tube that fits well over the remaining section, and forge a new foot on
    that. Attach the tube by brazing, friction, or even araldite (if you have a
    good overlap).
    newshound, Dec 13, 2008
  9. Nick
    bod43 Guest
    Easiest thing is to design the change so that it is not dependent
    on a perfect joint.
    e.g. saw it off a bit above the bottom, use a bit of
    mild steel tube to go over the bits and braze it.
    As long as the stuff is iron-ish then not much ot go wrong there.
    Obviously for brazing metal must be bright and clean.
    Even crap welding will likely do the business too.
    bod43, Dec 13, 2008
  10. Nick
    Everybody makes such a fuss of a little carbon these days
    Hog, Dec 13, 2008
  11. Nick
    Nick Guest
    Yes - thanks for the tip - I'll go and look for the hack-saw
    Thanks again,
    Nick
    Nick, Dec 13, 2008
  12. Nick
    Paging Bonwi...
    Oh, never mind.
    ogden, Dec 14, 2008
  13. I should hope so, unless Brunel had a hand in designing it.
    Cast steel should weld ok if a mig is waved at it, even in a shite
    fashion.
    Grimly Curmudgeon, Dec 14, 2008
  14. Nick
    That's a good idea.
    Andy Bonwick, Dec 14, 2008
  15. Nick
    Nick Guest
    Thanks guys,
    It seems its cast steel and is easily weldable with a MIG.
    I'll weld a slightly bigger footprint plate than it currently has, as it
    just sinks into soft tarmac on even a warm day.
    Nick
    Nick, Dec 14, 2008
