[QUOTE] Is it possible to weld a bit of stainless steel onto a bit of aluminium?[/QUOTE] Anything is possible - but IME that is particularly fucking difficult. The difference in melting points would make it impossible to get the stainless steel hot enough to be welded before the Al has turned liquid and run away.[QUOTE] There is a bodge on my bike which has broken and the bit of ali left over isn't big enough to weld it all back together again. The guys my dad uses [2] say you can't just weld the 2 bits together although TIG (?} might work.[/QUOTE] TIG might, but it would be more of a solder job than weld.[QUOTE] The alternative is to bolt the bit of steel onto the ali bracket, which I guess could work. Or bite the bullet and see how much Suzuki want for a new bracket :([/QUOTE] There you have your two options.
