Weird hex bolt size
Discussion in 'UK Motorcycles' started by Ben, Apr 19, 2007.
  1. Ben
    Ben Guest
    Tried to take the tank of the 10R last night (got a coolant leak from
    one of the hoses underneath and need to remove the tank to get a
    screwdriver onto the jubilee clip) and couldn't undo the bolts at the
    front of the tank.
    A 5mm hex key was too small and a 5.5mm was too big. What size is it
    likely to be?
    As it is I'm having the dealer sort it out on Saturday.
    Ben, Apr 19, 2007
  2. Ben
    Feel free to bitch-slap me, but are you sure it's hex & not torx?
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Apr 19, 2007
  3. Ben
    Jeremy Guest
    5.25 ?
    Jeremy, Apr 19, 2007
  4. Ben
    Ben Guest
    Consider yourself bitch-slapped. It's definitely hex.
    Ben, Apr 19, 2007
  5. Ben
    In that case you've bought a lemon - I'll give you 100 quid for it.
    Krusty
  6. Ben
    Ben Guest
    Duh. Why didn't I think of that?
    Ben, Apr 19, 2007
  7. Ben
    Ben Guest
    That's the weird thing, it was both sides.
    Did you have your fairings off the other day? I was amazed to find
    all those fasteners were 4mm, including ones under the seat securing
    it. Can see them rounding off in seconds if anything seizes.
    Ben, Apr 19, 2007
  8. Ben
    MikeH Guest
    Wrap some thick ally foil round a 5?
    MikeH, Apr 19, 2007
  9. Ben
    I'd take a file to a 6, myself. Failing that, an oversized Torx bit
    will do the job.
    Pip, Apr 19, 2007
  10. Ben
    Ben Guest
    I've got a couple of spare 6's I could do.
    On a brand new bike? No chance.
    Ben, Apr 19, 2007
  11. Ben
    Ben Guest
    I tried 2 keys, 1 allen socket head and 1 allen bit that came with my
    impact driver. All were too small. The 5.5mm key which is un-used
    was a whisker too big.
    Ben, Apr 19, 2007
  12. This has me in suspense I must say.
    How's the kitchen?
    mike. buckley, Apr 19, 2007
  13. Ben
    Ben Guest
    heheh, it's going back to the dealer next weekend and I'm not having
    it back until it's fixed. Whatever it is.
    Good. It went really well and has turned out nice...
    http://www.flickr.com/photos/bensales/sets/72157600030252414
    Ben, Apr 19, 2007
  14. Ben
    ginge Guest
    Ben, they're definitely 5's on my bike.. Curiosity got the best of me
    so I just went to the garage and undid both of them, one of which was
    torqued up tighter than I'd have expected, and has now gone slightly
    star shaped in the hex part..
    Looks like they're made of alloy, so might be worth replacing with
    stainless at some point, for the sake of longevity.
    ginge, Apr 19, 2007
  15. Ben
    Molly Guest
    £101.
    Molly, Apr 19, 2007
  16. Ben
    Beav Guest
    It's as likely to be a shite allen key as anything else. They're not always
    as accurate as the manufacturers would have us believe.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Apr 19, 2007
  17. Ben
    Ben Guest
    See my other post about using several keys and bits. I reckon it is a
    5mm, but just a loose enough fit that it'll probably round because
    they're either done up bloody tight or locktight'd.
    Either way I'm letting the dealer sort it as it's only 4 weeks old.
    Ben, Apr 19, 2007
  18. Ben
    ginge Guest
    The former, and they're unlikely to round, but there will be a slight
    mark where the face compresses.
    I'm still waiting for the dealer to get my Akrapovics. Think I'll ring
    them tomorrow and find out what's happening.
    ginge, Apr 19, 2007
  19. Ben
    Ben Guest
    Ben, Apr 19, 2007
  20. Ben
    You know, I haven't used a screwdriver on a gubile clip for 20 years.
    I got pissed off with the screwdriver slipping out and wrecking the
    screw slot, gouging bodywork, puncturing the hose or my hand - so I
    bought one of these:
    http://buy1.snapon.com/catalog/item.asp?P65=&tool=&item_ID=931&group_ID=19799&store=uk&dir=catalog
    The agent promised that it would never "rip, slip or turn inside-out"
    and it never has. Got me out of some tight corners too, even using
    prolly more torque than it was intended to take - but with a little
    6mm socket, it fits the hex heads of gubile clips a treat and I've
    never holed a hose nor a hand since.
    Pip, Apr 19, 2007
