Apologies if this looks a little different, I'm using Forte at the mo as Outpuke has gone tits up! Well after tinkering for a while with the swingarm bearings and adjusting them as per the HBOL I successfully stopped the weaving/wandering that plagued the SOBeemer,. Ta to all for advice, seemed quite simple given the amount of stuff that had to come off before adjustments made. No more wandering on the banding or white lines either. -- Robbo 1500GL 1988 Goldwing (Rebuild in process) BMW K100 RS 1984 "Fairly Quick" status. Silver level BotaFOF #19. E.O.S.M 2001/2002/2003. B.O.S.M 2003.FURSWB#1 KotL..YTC449 PM#7 ..
Aye, it's a piece of piss to do. Did you bother to remove the arm and grease the bearings, or did you just reset the torque? (I did put on some waterproof moly grease when I did it last though).
It was somewhere around Barstow, on the edge of the desert, when the There y'go. It's surprising how little adjustment makes a helluva difference. -- Dave GS 850 x2 / SE 6a SbS#6 DIAABTCOD#16 APOSTLE#6 FUB#3 FUB KotL OSOS#12? UKRMMA#19 COSOC#10
