Weak Tramp
Discussion in 'UK Motorcycles' started by sweller, Jun 8, 2008.
  1. sweller
    The fucking Kawasaki GT750 again.
    What would cause feeble sparks - and I mean feeble.
    Oddly it starts first press of the button and runs ok but the spark is
    pitiful. Really, really pitiful as in can't see or hear it except in my
    darkened lockup, and then it's only a tiny yellow flicker.
    Coils are good, caps new, HT leads new, plugs new - all of these were
    substituted at some point today and the spark remained the same.
    Is the igniter box a prime suspect? Connections were all broken and
    remade, all were shiny.
    Is the Turbo's igniter box the same? (I've only just thought of it).
    Any ideas?
  2. sweller
    SD Guest
    SD, Jun 8, 2008
  3. sweller
    Are the sparks equally weak on all plugs?
    platypus, Jun 8, 2008
  4. sweller
    Yes - I should have said, with intermittent no shows on any one of the
    four. Which makes it run a bit crap but it'll idle and still be
    rideable, just "a bit crap".
    ....and hellishly thirsty, which makes me think the poor spark may be part
    of the problem.
  5. sweller
    So it's not the plugs, leads, coils etc, unless they're all equally duff,
    which is unlikely. I'd check that the battery connections are clean and
    beautiful, and that there's no significant resistance in the earth circuit
    from the cylinder head back to the battery terminal, using a meter.
    Yep. Fix the spark problem, then see if you still have the fuel consumption
    problem.
  6. sweller
    *ding*
    use a jump lead to provide a temporary earth
    wessie, Jun 8, 2008
  7. sweller
    Alex Ferrier Guest
    Had the same problem on a FJ12 once. In my case it turned out to be a flat
    battery and bad battery earth.
    Alex Ferrier, Jun 9, 2008
  8. sweller
    zymurgy Guest
    Are you sure about the coils ?
    It would be my first port of call. Could you have subsituted another
    duff one in ?
    P.
    zymurgy, Jun 9, 2008
  9. sweller
    zymurgy Guest
    They are fuckers with bad batteries. Mine refused to start even after
    being jumpstarted and powered directly from a fully charged battery in
    my diesel 4x4.
    Turned out to be the battery after all, after me suspecting solenoid/
    starter et al ..
    P.
  10. Indeedly, that's a result of crap sparks. If you've gone over all the
    wiring and all the connections are good - HT and LT - then the ignitor
    box is prime suspect, especially with the intermittency. Thinks... have
    a bloody good look at the pickup coils - they live in a very hostile
    environment and it's certainly not unknown for them to give exactly this
    symptom when they're on the way out - also, it might just be a duff
    connection down there. Out of sight, etc.
    GS850x2 XS650 SE6a
    "It's a moron working with power tools.
    How much more suspenseful can you get?"
    - House
    Grimly Curmudgeon, Jun 9, 2008
  11. sweller
    No, I had the known good pair off the turbo and it made no difference.
    sweller, Jun 9, 2008
  12. sweller
    The battery is only six weeks old and it spins over fine.
    I'll go through and check the earths just to make sure.
  13. sweller
    sweller, Jun 10, 2008
