I have a 1982 KZ-750 E (4 cylinder) that runs great. I am having a problem with hot starting. When the bike is cold, the starter cranks the engine over Ok, and the bike starts well. After riding the bike for a while (10-20 minutes) if I shut the engine off, the starter will not crank the engine over. It tries to crank, but it just doesn't have enough power to spin the engine over. The battery is new, and it holds a charge well, and the charging system checks out Ok. I have 14.5 volts at the battery at 4000 rpm. If I let the engine cool off for a while, the starter will crank the engine over and the bike will start. I suspect that my starter is just weak after 26 years of use. I was just wondering if anybody else has encountered a similar problem. I am going to try to pick up a used starter at a junkyard, or possibly pull my starter apart and take a look at the brushes. Thank You for your help! Greg
