way OT, laptop mobo schematics
Discussion in 'UK Motorcycles' started by Gazz, Feb 26, 2010.
  1. Gazz
    Gazz Guest
    i'm sure i've seen people post similar Q's on here before and been helped
    out, so i may as well try my luck.
    i've got an old-ish laptop, it let the magic smoke out one day after a loose
    screw in the case shorted something out, it still worked but didnt accept
    power, so when the battery dies that was it.
    i got a new lappy and put the old un in a box and forgot about it, just
    found it again so thought i'd see if i can get it going again, i only want
    it to hook my multimeter to so i can use the recording and large display
    thingies it does via a usb connection, and it'd be handy to use it for
    running the vinyl cutting software i use, as that dosent take much
    processing power up, and hence it'd be handy to have a lappy in the room i
    have the cutter in rather than having to cart the one i use to surf for porn
    in bed to the cutter everytime i want to cut some vinyl.
    The laptop is a Acer Aspire 1350, model # MS2159... if that's any use,
    the blown chip is an 8 pin surface mount, (U43 on the board) it's mounted
    right after the DC input connector from the + terminal,
    i can make out 4407 clearly, and then all i can see is 1H, the rest is
    obliterated,
    anyone know where i can find out what the IC is to replace it? i have tried
    acer support, but they wont tell me, said send it in and they'll charge me
    about the price of a new laptop to try and fix it,
    i know i could get the lappy working by applying power to the battery input
    terminals, but that'd be a faff as i expect it will want to see the correct
    individual cell voltages on all the connectors rather than just a 14 volt
    ~DC input.
    Gazz, Feb 26, 2010
  2. Gazz
    4407 is a MOSFET (simple search on google "4407 IC")
    http://www.alldatasheet.com/datasheet-pdf/pdf/102778/ANACHIP/AF4407PS.html
    If you have done something to make that make magic smoke then there will
    probably be a domino effect on other stuff
    wessie, Feb 26, 2010
  3. Gazz
    zymurgy Guest
    If it's surface mount, forget it. Nige it out for spares or repair on
    ebay and get on with your life ..
    Paul.
    zymurgy, Feb 26, 2010
  4. Gazz
    While agreeing totally with wessie's comment, even I can change an 8
    pin SMD.
    As it's a case of 'nothing to lose by trying', either use *really*
    fine cutters to snip the pins off individually or a scalpel to
    carefully hack through them one at a time, in both cases right up
    aginst the IC body , then gently sweep the stubs off with a soldering
    iron.
    You don't need the schematic to check that the input pins to the chip
    are geting the right voltages, only the chip pin-out.
    A touch of solder to tin the pads first, or a dash of flux may help.
    Afterwards, if you've got any solder braid, use that to clean the
    pads, otherwise, lightly tin them so they're all even and shiny then
    tack a new chip down.
    This may or may not work, but as I said, you've nothing to lose except
    a little time and patience and one replacement chip.
    Personally, I wouldn't bother but then, useful as they are, I hate
    PCs.
    Pip Luscher, Feb 26, 2010
  5. Gazz
    zymurgy Guest
    ****** *That*
    And I have worked with SMD stuff in the past.
    Well, once you've butchered the motherboard it's worth **** all on
    Ebay, so you might as well punt it there than throw it in the bin.
    Pretty much my sentiment
    Me, I love 'em.
    Bread and butter y'see ....
    Paul.
  6. Gazz
    it's a piece of piss - just flood the legs of the IC with solder, when both
    sides of the IC are sitting in liquid solder lift off the device. Most of
    the solder comes away and any crud on the pads. Quicker than using the
    proper reflow hot air toys we had.
    Unlikely to work. The heat from the burning MOSFET has probably damaged the
    pads & base layers in a terminal fashion. Laptop mobos are made of cheese,
    Kraft slice cheese. Then there's the other devices...
    <ding>
  7. Gazz
    Hmm. Used to do the for through-hole devices and it did work, however,
    whenever I've tried that on modern PCBs, the sheer heatsink effect of
    power or ground vias has prevented the solder from flowing enough for
    it to work before the pads lifted. Still, I haven't tried it on cheapu
    mobo's. I really, really hate PCs. They're disposable consumer goods.
    Well, as long as the tracks or vias are still attached, not a problem.
  8. Gazz
    I got me one of those.
    Lozzo, Feb 26, 2010
  9. Gazz
    'Real men don't use braid' eh?
    I can recall having my own solder sucker at work, the PTFE tip trimmed
    just so; the pin and barrel kept clean to minimise friction; the
    piston face spotless to minimize inertia and the foam washer carefully
    scrubbed and even lightly trimmed to prevent undue drag, for maximum
    suck.
    Tuned, you know, tuned to perfection.
    [I was going to try for a hot-rod gag involving soldering irons but
    ICBA to think]
  10. Gazz
    geoff Guest
    Broken ?
    We wear them out in a couple of months
    geoff, Feb 26, 2010
  11. Gazz
    Gazz Guest
    Braid!! Braid is for poofs and other wimmin of a nervous disposition. A
    **** that, i use me desolder / solder station thingy i got for xmas, i set
    the heat to low-ish, gently wigglesd the nozzle on the pins, pressed the
    trigger and 'brrrrrr sluuuurp' and the solder is gone.
    the tip on the soldering iron is just small enough for the IC in question to
    enable me to have a fairly good chance at splodging some solder down in the
    right places to attatch a new un,
    i am quite expecting the new ic to blow again, there's deffo signs that the
    loose screw in the case touched the ic in question, not something further
    down the line.
    and i always have the option of powering it via the battery input
    terminals, but it'd be easier if i could use the psu plugged into the
    charge/power socket than faff about with hacking cables to the mobo to power
    it via a psu thru the battery input.
    btw, i found the 4407 ic's, but there are a fair few options for them, i
    figured the other number on the chip would have told me which particular
    flavour of 4407 i need,
    Gazz, Feb 27, 2010
  12. Gazz
    <sniff>
    Some of us didn't have to undo our work that much.
    Pip Luscher, Feb 27, 2010
  13. Given that the device is a MOSFET and 3 pins are connected together
    for source and all four on the other side connect to drain, I don't think
    the soldering is going to be very critical, except for that one gate pin.
    Dr Ivan D. Reid, Feb 27, 2010
  14. Gazz
    Gazz Guest
    this 4407 mosfet jobbie,
    anyone know where i can buy one from? seems AF4407P or AN4407P are the most
    common ones, the first letters are just the manufacturers name code anyway,
    but i'm stuck finding where to get one, tried RS components, farnel,
    maplins,
    unfortunately that's my lot of component places i know of.... or ones that
    will sell a small quantity, i know i'll prolly have to buy 5 for min order,
    i found some on ebay but they are in portugal, so i'd rather keep that as a
    last chance, as i'd like to get this damn thing asap, or i'm going to loose
    bits to the laptop, i did have the screws all lined up as they came out of
    their holes, but that's gone to pot in one swift hand movement when i needed
    room on the bench.
    Gazz, Feb 28, 2010
