Waterproofing textiles
Discussion in 'UK Motorcycles' started by Gingerpose, Jun 24, 2004.
  1. Gingerpose
    Gingerpose Guest
    How?
    Cos the rain-deflecting properties of my trousers hae faded. What's the
    recommended way of treating them so they offer my knackers a bit of
    protection from the nasty Scottish rain?
  2. Gingerpose
    Mark Olson Guest
    Scotchguard
    Mark Olson, Jun 24, 2004
  3. Gingerpose wrote
    New ones, the only answer really and you know it. While you are making
    up your mind which ones to buy try some of that spray on tent proofer
    stuff that tent selling places sell.
    steve auvache, Jun 25, 2004
  4. See, I read that as "Waterproofing testicles", which amounts to the same
    thing really. A good quality varnish?
    Si
    Mungo \two sheds\ Toadfoot, Jun 25, 2004
  5. "New ones" - seconded! :)
    I am also informed by those with considerably more expertise than me
    in the design and manufacture of waterproof fabrics, that effort to
    maintain the outer surfaces of the garments in as clean a condition as
    possible (given the rigours of motorcycling useage) is beneficial.
    They explain that deeply engrained dirt will hold water and this could
    find its way through any chinks that develop in the waterproof barrier
    (as well as increasing heat losses from the body). Additionally,
    spraying the outer surfaces with some form of water repellant
    treatment, after washing, will also enable rainwater to be shed more
    easily, further enhancing the waterproofing properties of the garment.
    Paul Varnsverry, Jun 25, 2004
  6. Gingerpose
    This is certainly the case with mountain-type clothing - newly washed
    jackets (using proper gore-tex wash, of course) are much warmer than
    dirty old ones.
    I'll have to look into whether my bike jacket's washable. Trouble is,
    it's got external armour on the elbows and shoulders, so I'm not sure
    if a machine wash is really a good idea :-}
    Ace, Jun 25, 2004
  7. Gingerpose
    Nikwax "Tekwash" seems to work...up to a point - depends on how badly
    fucked the original waterproofing is.
    darsy, Jun 25, 2004
  8. Fabric softeners will *destroy* some types of impact foam! The
    manufacturer of your jacket should be able to provide you with
    cleaning instructions, if none were supplied with it/are printed on a
    sewn-in label.
  9. Gingerpose
    Thanks, but this isn't foam, but a hard external shell. It's a Dianese
    gore-tex jacket with full articulated back protector (removable) as
    well.
    Oh aye, I'm sure it's in there somewhere. But I suspect it may be
    hand-wash only, or perhaps require a large-capacity machine, because
    of the rigidity of said hard armour.
    Ace, Jun 25, 2004
  10. Gingerpose
    Angle grinder.
    platypus, Jun 25, 2004
  11. Gingerpose
    Molly Guest
    NikWax.
    Molly, Jun 25, 2004
  12. Gingerpose
    Knickwax, Shirley.
    Or Knackerwax, for making sure.
    Pip, Jun 26, 2004
  13. Gingerpose
    Molly Guest
    You're getting the knack of this aren't you?
    Molly, Jun 26, 2004
  14. Gingerpose
    I'm trying.
    Pip, Jun 26, 2004
  15. Does the manufacturer claim the garment features protectors approved
    to EN 1621-1?. If so, there must be some foam in there somewhere, as
    plastic alone will not attenuate transmitted force (unless the
    "protectors" are not protectors at all, merely "plastic decorations")
    Paul Varnsverry, Jun 27, 2004
  16. Gingerpose
    **** nose. Such things are not high on my list of things to look into
    when buying a jacket.
    I'd imagine the former there's certainly some padding there. It's a
    'techno touring' jacket, bought in 2001 and no longer available,
    AFAICT. cost about 400 quid, IIRC, and has been worth every penny.
    Ace, Jun 28, 2004
