Waterproof treatment for leather jacket?
Discussion in 'Bay Area Bikers' started by thejen12, Jan 14, 2006.
  1. thejen12
    thejen12 Guest
    My Hein Gericke V-Pilot jacket gets soaked through in the rain pretty
    fast (faster than it used to). Is it okay to put some kind of
    treatment on the jacket to waterproof it? Or at least make it more
    water resistant? Any recommended products?
    Thanks, Jenn
  2. thejen12
    bearclaw Guest
    Mink oil.
    bearclaw, Jan 15, 2006
  3. You ought to check with the mfr. for a recommendation.
    I use SnowSeal on my winter gloves, but this tends to cut down the
    breathability, which could be a problem in summer. I'm using a Nikwax
    product from REI on my goretex boots.
    To really nuke a problem area, I'll use a mix of wax and Campmor
    Silicon spray, but again only if I'm willing to give up breathability.
    I also treat the front of my gear a lot more heavily that the back,
    as the front is the part that really gets blasted with water. The
    backside I'll try to leave very lightly treated.
    Rob Kleinschmidt, Jan 16, 2006
  4. thejen12
    thejen12 Guest
    Thanks for the suggestions! I happen to have mink oil at home, so I'll
    probably try that. My main problems are on the upper arms - as you
    pointed out, some parts of the jacket need only be lightly treated or
    maybe not at all. Since I wear a different jacket in the summer, I'm
    not as concerned about breathability with this jacket.
    Jenn
    thejen12, Jan 17, 2006
  5. SnowSeal is pretty good stuff. You apply it then blow some heat
    at it with a heat gun or hair dryer to melt it into the leather.
    REI has a bunch of more newfangled stuff that actually seems
    to work pretty well too.
    Rob Kleinschmidt, Jan 17, 2006
