water filled gloves
Discussion in 'UK Motorcycles' started by dundonald, Apr 22, 2004.
  1. dundonald
    dundonald Guest
    Got soaked the other day. Made worse more so by the fact that water dripped
    down my sleeves into my gloves, particularly my left glove (for some
    reason!). Suggested solutions please?
  2. dundonald wrote
    Don't stop. And if you do raise you hands above your elbows.
    steve auvache, Apr 22, 2004
  3. dundonald
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, dundonald
    Put your sleeves over your gloves in very wet weather.
    Really.
    Nigel Eaton, Apr 22, 2004
  4. dundonald
    Grand Hailing Sign of Distress.
    platypus, Apr 23, 2004
  5. dundonald
    Wik Guest
    Perzackerly.
    Mine dew, my "old" Belstaff's jacket sleeves were a tad too short for
    this, may be a problem yet for the OP...
    | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Apr 23, 2004
  6. dundonald
    AONTL.
    Ace, Apr 23, 2004
  7. *ding*
    And the same for trousers.
    William Grainger, Apr 23, 2004
  8. dundonald
    Cab Guest
    William Grainger wrote:bored us all completely to death with wittery
    prose along the lines of:
    Eh, trousers over your gloves?
    Alright, alright, I'll get me coat...
    Cab :^) - Ormiga Atomica
    GSX 1400 - 'Tarts Handbag' (tm) Bike, dead 550/4 Rat
    UKRMMA#10 (KoTL), IbW#015, Bob#4, POTM#3
    P.S. Remove your_head from the cab. ICQ: 83023471
    Cab, Apr 23, 2004
  9. dundonald
    Ace, Apr 23, 2004
  10. dundonald
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Ace
    Nigel Eaton, Apr 23, 2004
  11. dundonald
    dundonald Guest
    Aye but what about wind up your sleeve?
    dundonald, Apr 24, 2004
  12. dundonald
    dundonald Guest
    So when it starts to rain, pull over, pull trousers and sleeves out. Bugger
    when you're on a motorway though.
  13. dundonald
    dundonald Guest
    Thanks, I'll check them out. I need new gloves anyway.
  14. dundonald
    dundonald says...
    They're called the Master 4 glove, IIRC.
    Lozzo, Apr 24, 2004
  15. dundonald
    Verdigris Guest
    I've never found it to be a problem, although it does depend on the
    jacket. Provided there's a strap to tighten it at the wrist it should be
    OK.
    Verdigris, Apr 24, 2004
  16. dundonald
    dundonald Guest
  17. dundonald
    dundonald Guest
    Ah right. Well I went to gloves and found the only master option in there.
    Tbh they don't look like the ones you talk of, but are the only ones with
    master as part of the range name.
    dundonald, Apr 26, 2004
