WARNING: More Motorcycle Content
Discussion in 'Texas Bikers' started by ?, Jun 8, 2010.
  1. ?
    ? Guest
    That depends on whether you're riding the street or on the race track.
    The tire companies send trucks full of race tires to the club races at
    Willow Springs and they will inflate the fast guys' tires with
    nitrogen and the novices' tires with air.
    I've gotten race compound tires hot enough to make the rubber melt and
    ball up on Willow and I wasn't going that fast.
    Well, you are *wrong*.
    I weigh 250 pounds (the equivalent of two S'mees).
    You also don't know what my rear spring rate is, or what Yamaha
    believes is the typical weight for a rider or a passenger.
    I'm guessing that Yamaha thinks that the typical weight for each is
    180~190 pounds, because the rear spring is rated at 386 pounds per
    inch.
    But the swing arm has a mechanical advantage of about 3:1 on that
    spring, so
    the effective rate (without considering the rising rate effect of the
    linkage lever) is 386/3=129 pounds/inch.
    The rear axle moves through an arc of 130mm (5.122 inches).
    Adjusting the laden rear suspension to the maximum recommended sag
    of 40% with me aboard leaves me with 2.05 inches of wheel travel, so
    the spring should be adequate to support 258 pounds at slow cruising
    speed.
    There is also a rubber bump stopper on the shock absorber shaft to
    keep the mechanical parts from banging against each other.
    I don't know what the free length of the spring is in order to figure
    out how much initial preload is on the spring, but the range of
    preload adjustment is 10 millimeters.
    The rear spring is now preloaded to 3 millimeters.
    No, setting sag is *not* stupid simple. Sport riders wouldn't know how
    to begin setting sag if the magazine guys didn't write articles
    telling them how to do it.
    I followed manufacturer's recommendations and I followed the
    instructions for setting static sag and race sag that were published
    in Sport Rider.
    At 30% loaded sag and the owners manual recommended tire pressure of
    38 pounds, the result was a motorcycle that was so rigid it made my
    eyeballs jiggle on the freeway and I couldn't focus on the road ahead.
    So I started gradually reducing front and rear preload and increasing
    sag.
    I must disagree. Remember that it was the Egomanical Tim Morrow that
    introduced "mile eater" to this discussion, not me.
    But...
    The FZR1000 was described in the magazines as a "sport tourer with the
    focus on sport," and later as a "power bike," similar to Kawasaki
    ZX11's, ZX12's, etc.
    One 1990's Los Angeles-based magazine article described the FZR1000 as
    the sportbike you would want to be on, if you just had to be in Denver
    in the morning and you didn't want to fly.
    The FZR1000 was the Hayabusa of its period, with lots of straight line
    power, but not so nimble in the twisties.
    Nothing could stay with an FZR1000 when it came onto the power band
    above 8000 RPM.
    Up until the CBR900RR was introduced, the FZR1000 was the standard by
    which all other sportbikes were judged.
    All comparision tests between multiple models of big bore sportbikes
    always included an FZR1000 in the 1990's.
    However, one important piece of information that you may have missed
    is my description of the poorly paved county road that is so rough it
    influenced my decision to reduce suspension preload and tire pressure
    for comfort.
    This mountain road has been in existance since the 1820's, when
    explorers like Jedediah Smith and Kit Carson used it to avoid
    travelling through the swamp in the middle of California. General John
    Fremont moved his army troops along this road on the way to Sacramento
    during the Mexican War.
    Stagecoaches followed this road to deliver the mail to Sacramento and
    San Francisco during the gold rush.
    I don't know when it was paved, or the last time it was repaved, but
    it's full of potholes and patches and ripples and it gets used by
    gravel trucks and it goes past my house.
    My other choices are to ride an equally rough county road through the
    grape vineyards and battle pickup trucks driven by Mexicans who can't
    understand why I'm going so slow, or to play tag with the 18-wheelers
    on the state highway and get tossed around by their wake.
    ?, Jun 10, 2010
  2. Of course....the thread is street operation....not the track. On the street, nitrogen filled tires never get warm enough.
    Steve
    Steve Lusardi, Jun 10, 2010
  3. ?
    S'mee Guest
    wrong again lying pedo. 8^) I'm a light weight 190# 15-20% body fat
    AND I've got better cardio than the average.
    Oh by the way after trimming all your bullshit and unattributed cut
    and pasting the only thing left was you once again talking about
    things you know nothing of and your betters (pretty much everyone on
    reeky, tx.motorcycles and AMS)
    I suggest you take that lying ass of yours out to the bay and drown
    your self.
    3-7-77
    S'mee, Jun 10, 2010
  4. What do you mean I'm wrong. You start a tread with a question. You then reject all suggestions. What's wrong with this picture?
    Your bike is sprung to support two average weight riders of say 180 lbs. You weigh 250. Set up correctly it will not bottom
    out...... period. End of discussion. Yamaha is not stupid. You stated that properly set up, the ride is too harsh....that's
    subjective. It is your assessment. I can't argue with that...against that I stated, you then have the wrong machine....that's not
    subjective. That conclusion cannot be avoided. Another contributor suggested you modify the suspension. You rejected that. Other
    people's assessment of your bike is not relevant to this discussion. Neither is melting race tires at Willow. Go buy an African
    Twin or move to another house.
    Steve
    inch.
    spring, so
    speed.
    in Sport Rider.
    sag.
    But...
    above 8000 RPM.
    for comfort.
  5. ?
    Tim M. Guest
    All of the laboriously typed self justification and whinging in the
    world doesn't alter the fact that you are responsible for setting your
    suspension and tire pressures to match the conditions that you are
    riding in, and if you are riding an FZR1000 (highly unlikely, given
    your history of prevarication) and can't keep up with riders on full
    dress Harleys - REGARDLESS of the road conditions and REGARDLESS of
    the suspension settings - then you are, without a doubt, incompetent.
    Whether yout incompetency in riding is greater or less than your
    incompetency in suspension set-up is a moot point.
    Tim M., Jun 10, 2010
  6. ?
    Tim M. Guest
    Nothing at all. This is TOTALLY normal for the racist jerk, trying to
    hide behind actual motorcycle content. He knows NOTHING about
    motorcycles, but he has no life ands all the time in the world, so
    this is his way of diddling himself.
  7. ?
    ? Guest
    As the sulfur that bonds molecular chains of rubber begins to melt at
    234°F~246°F the rubber compound begins to devulcanize, and the rubber
    on the surface of rear tire begins to slough off, turn into "smileys,"
    and then begin to roll into little black balls...
    http://www.csgnetwork.com/prescorh2oboilcalc.html
    Add 29.4 PSI *gauge* inflation pressure to the 14.7 PSI *absolute*
    pressure which your pressure gauge doesn't indicate and you get 44.1
    PSI Absolute in your tire, which is 89.76 Inches Hg.
    The BP of H2O is 322.810°F at 44.1 PSIA. If the rider isn't getting
    his tires up to
    323°F, he isn't boiling the condensation inside his tires and doesn't
    *need* nitrogen.
    When water boils, it expands by a factor of 1600:1...
    The amount of water in compressed air can vary widely, though. I won't
    dig into my steam engineers books to get into the effect of this
    pressure rise on the
    *volume* of the tire, even though volumetric increase due to pressure
    rise *does* affect the *size* of the tire's contact patch.
    If you *ass*-ume that air (or nitrogen) is a perfect *dry* gas, you
    can calculate the *linear* rise in tire temperature by using the
    formula
    P1/T1 = P2/T2
    Where pressure is absolute and temperature is expressed in degrees
    Kelvin for the metric system or degrees Rankine for the English
    system.
    With an initial inflation pressure of 36 PSIG at 59°F and a final
    (hot) pressure of 40 PSIG, the calculation is as follows:
    ( 36 + 14.696 ) / ( 59 + 459.67 ) = ( 40 + 14.696 ) / ( X + 459.67 ) ;
    50.696 / 518.67 = 54.696 / ( X + 459.67 ) ;
    0.0977423 = 54.696 / ( X + 459.67 ) ;
    54.696 / 0.0977423 = ( X + 459.67 ) = 559.5935° Rankine
    559.5935° Rankine - 459.67 = 99.92° Fahrenheit.
    If you want to work this problem out *including* the inscrutable
    factor of *volume,* the formula is
    ( P1 * V1 ) / T1 = ( P2 * V2 ) / T2
    Ya didn't know you were talking to a former rocket scientist and steam
    engineer, didja?
    ?, Jun 10, 2010
  8. ?
    Tim M. Guest
    Fixed that for you, Krusty.
  9. ?
    ? Guest
    Why can't I get a *straight answer* to the original question: "Has
    anybody ever been in a situation where they were tempted to *reduce*
    air pressure in their tires for comfort during a ride?"
    Couldn't that question be answered by a simple "yes" or "no," perhaps
    followed by an anecdote?
    ?, Jun 10, 2010
  10. ?
    ? Guest
    For some strange reason, I'm thinking of you as Joe Buck in the scene
    in the print version of "Midnight Cowboy" when the drag queen sat on
    his face:
    You're gasping for air, Keith.
    ?, Jun 10, 2010
  11. ?
    ? Guest
    So? How do you like me now?
    ?, Jun 10, 2010
  12. No
    The Older Gentleman, Jun 10, 2010
  13. ?
    Tim M. Guest
    Probably because you, along with everyone else following this trend,
    down to and including the most RANK beginner, has NEVER misadjusted
    their supension sp badly and/or ridden so inappropriately for the
    conditions at hand as to have ever so much as contemplated that the
    correct way to address the situation (of theor OWN making) was to do
    something so marginal as change the air pressure in their tires.
    Everyone, that is, except the racist incompetent fool who started this
    thread.
  14. ?
    ? Guest
    So. You *never* adjusted your air pressure at the racetrack to improve
    traction, huh?
    ?, Jun 10, 2010
  15. ?
    saddlebag Guest
    Hence my statement about needing to ride them all.
    saddlebag, Jun 10, 2010
  16. ?
    BryanUT Guest
    Confession time. When I rode to PHX with Troy, I hadn't bothered to
    check the tire pressure on my bike. When we got to Bob's house he had
    a really cool pressure gauge and I decided I should check the
    pressure. Yep, right around 25 lbs in each tire, maybe less. 700
    miles at fairly high speeds, I never even noticed. Yeah the steering
    was a bit slugish, but what the heck.
    BryanUT, Jun 10, 2010
  17. ?
    Tim M. Guest
    No, I didn't. Of course, I had my suspension setup correctly shortly
    after learning how to race, and I always had the right tire pressures
    based on the tire vendor's recommendation, the advice of my sponsors,
    and the ambient and track temperatures.
    Besides, you weren't racing when the biker dudes on the Harley
    dressers left you for dead on the street while you were supposedly
    "riding" your FZR1000, were you, big mile eater?
    Oh, and you weren't worried about TRACTION, dumbass, you were worried
    about COMFORT: "Has anybody ever been in a situation where they were
    tempted to *reduce* air pressure in their tires for comfort during a
    ride?"
    Sheesh, you are embarrassing yourself even more than usual, something
    I thought wasn't possible.
    Tim M., Jun 11, 2010
  18. ?
    Tim M. Guest
    Ah, gotcha. I misunderstood the context of your statement. Re-
    reading it, I see what you actually meant. Thanks for the
    clarification. Strike my comment.
  19. ?
    ? Guest
    Mmmmm, *why* don't I feel embarassed, then?
    ?, Jun 11, 2010
  20. ?
    Twibil Guest
    Simple:
    Because you're too stupid to understand that you've just stepped on
    your own prick again, and you're too self-centered to admit having
    done so -even if you *were* bright enough to have figured it out.
    Even with your racisim, homophobia, and chauvinisim aside; your lies,
    stupidity, arrogance, and utter lack of motorcycle knowledge
    permanantly damn you to the reception you get here.
    Twibil, Jun 11, 2010
