Wanting to do an Oil Change
Discussion in 'Motorbike Technical Discussion' started by 12wanderer12, Dec 14, 2006.
  1. Sounds interesting. Time for a long Google, methinks.
    The Older Gentleman, Dec 16, 2006
    #41
  2. 12wanderer12
    Steve Parry Guest
    In
    Which is why I always preferred pre powervalve RD's
    Steve Parry, Dec 16, 2006
    #42
  3. 12wanderer12
    Steve Parry says...
    The 350F2 was a fast bike, for what it was, tested at 125mph by a couple
    of mags. The earlier non-pv bikes would be hard pushed to reach that
    when professionally tuned. I loved the last powervalve I had, it was a
    cracking little bike. The earlier 4LO bikes handled better than the
    first of the 31K powervalves, but Yamaha soon got on the case and sorted
    that out. I'm not a fan of the 31Ks apart from their engines.
    Lozzo, Dec 16, 2006
    #43
  4. 12wanderer12
    Gene Cash Guest
    Yes, that was the theory at the time.
    -gc
    Gene Cash, Dec 17, 2006
    #44
  5. That's what I had - a blue/yellow one, bought new.
    You could gear them up, because they'd easily spin into the red in top
    at about an indicated 120. The taller gearing (one more tooth on the
    gearbox sprocket) made them a bit more relaxed at cruising speed,
    improved economy slightly, and they'd still pull to the redline in top
    at (IIRC) an indicated 127 or something.
    Trouble was, that it moved the power-valve flat spot further up the rev
    range. You know: the sort of black hole at 6000rpm when the PV can't
    decide whether to open fully or not.
    On stock gearing this happened at 70-75 mph in top, which wasn't a
    problem, but with the higher gearing it happened at about 80+, which was
    really irritating. So I put it back to stock gearing in the end.
    The Older Gentleman, Dec 17, 2006
    #45
  6. Ahem! You know better than that, Neil.
    That's not moving it up the *rev range*...
    Dr Ivan D. Reid, Dec 17, 2006
    #46
  7. My bad. I meant "up the speed range".
    #47
  8. 12wanderer12
    Frank Guest
    I'm pretty sure your Honda uses the same filter that my '86 FJ1200
    Yamaha used. I used Frams in it for years just because my local Yamaha
    shop pissed me off so bad I wouldn't go in there. Then I bought my
    Kawasaki ZRX in '99, and it used the same filter. After that I used
    Kawasaki filters in it until I sold it. You might check some cross
    references and check the filter for your Honda against the filter on
    '86 Yamaha FJ1200 and '99 Kawasaki ZRX1100.
    Frank, Jan 1, 2007
    #48
