Wanted: Fuel tap for Rat
Discussion in 'UK Motorcycles' started by Pip, Sep 4, 2003.
  1. Pip
    Pixies on the scrounge ...
    The infamous Rat came to us with no fuel tap whatsoever, the original
    tank having had a tap attached to the it and the ZXR tank which is
    currently in residence has two take-offs to run to a frame-mounted tap
    but both hoses meet at a T-piece which then runs to the carbs.
    Life would be a lot easier with a proper main/reserve tap, obviously.
    Does anybody out there have a suitable tap which is surplus to
    requirements that you could stick in the post in exchange for a
    beer-token sized cheque? Size and appearance immaterial, as it will
    be molished into place wherever it will fit and painting is a
    certainty in any case.
    Fanks ;-)
    Pip, Sep 4, 2003
  2. Pip
    With two old sockets welded to the end, or they cut the pipe. :)
    Muck, Sep 5, 2003
  3. Pip
    Turning it off isn't a problem Alan. Finding some way to access a
    reserve is the problem ... otoh ... two pipes, the reserve brutally
    closed but openable when needed would be a way forward ...
    Pip, Sep 5, 2003
  4. Pip
    Richard Wood Guest
    Reserve running through a long rubber pipe which is folded over and stuffed
    in a gap betwixt frame and tank to block it until needed...?
    Might be fun trying to find it whilst on the move mind you... so piece
    of string from pipe to somewhere on the bars. Voila! Pull cord reserve
    tap :)
    frag
    Richard Wood, Sep 8, 2003
