Waddaya supposed to do with cases, again?
Discussion in 'Australian Motorcycles' started by IK, Oct 29, 2005.
  1. Rear brake not binding?
    lemmiwinks.au, Nov 3, 2005
  2. JL said....
    Like a part of the tensioner falling into the engine and is jamming
    it....
    Martin Taylor, Nov 3, 2005
  3. IK
    IK Guest
    OK, OK.... summarising, for both you and JL.
    -Rear wheel, in gear: bloody hard to turn, even with the plugs out (so
    no compression to impede proceedings).
    -Rear wheel, in neutral: as easy as you'd expect it.
    -Crank, in gear: turns over smoothly with the normal, moderate amount of
    resistance, both with plugs in and out.
    -Crank, in neutral: as above, with no perceptible drop in resistance
    (this is what I mean by saying that you have to look at the rear wheel
    to see if it's turning to figure out whether you're in gear or not; you
    can't tell just by how hard you're tugging on the ratchet)
    IK, Nov 5, 2005
  4. IK
    smack Guest
    funny
    smack, Nov 5, 2005
  5. Ah, your clutch is rooted.
    Hammo
    Hamish Alker-Jones, Nov 5, 2005
  6. IK
    Would've been funnier if BT had've said it!
    Clem
    Knobdoodle, Nov 5, 2005
  7. IK
    IK Guest
    How you figure that one?
    IK, Nov 5, 2005
  8. 'cos when it is engaged, it is giving you problems.
    H (probably explained the higher than average fuel consumption, but, from
    here, I could say it could be anything).
  9. IK
    I'm not as funny in real life though.
    BT Humble, Nov 6, 2005
  10. IK said....
    Which gear? If 1st, then it will be hard to turn over, given the
    mechanical (dis)advantage that low gearing offers.
    Martin Taylor, Nov 6, 2005
  11. IK
    Theo Bekkers Guest
    Box in top gear? Will be a lot harder in first.
    Theo
    Theo Bekkers, Nov 7, 2005
  12. IK
    Theo Bekkers Guest
    The clutch is not engaged in neutral? Hmm, next you'll be saying all the
    cogs in the box remain stationary in neutral.
    Theo
  13. IK
    Theo Bekkers Guest
    Damn, nearly a day late. :)
    Theo
  14. IK
    Conehead Guest
    It sounds like there's something wrong with it.
    smack
    Conehead, Nov 7, 2005
  15. Of course they will. Just don't be moving (be stationary as you like to
    call it).
    Hammo
    Hamish Alker-Jones, Nov 7, 2005
  16. IK
    sharkey Guest
    I tried building a model gearbox out of paper, but when I put
    it in gear it remained stationery.
    -----sharks
    sharkey, Nov 7, 2005
  17. Well, _half_ of them will...
    big
    Iain Chalmers, Nov 7, 2005
  18. IK
    Theo Bekkers Guest
    Hammo, he is describing what happens when he turns the engine.
    Theo
  19. IK
    Theo Bekkers Guest
    Which half? In my gearbox all the gears turn in all gears, including
    neutral. In neutral however, some of the shafts don't turn.
    Theo
  20. IK
    [applause]
    Knobdoodle, Nov 7, 2005
