VS800 Clutch
Discussion in 'Motorbike Technical Discussion' started by Useagroves, Dec 12, 2005.
  1. Useagroves
    Useagroves Guest
    Can anyone tell me the order and orientation of the two rings that live in
    the back of the clutch pack of a 94 VS800 Intruder? I looked up a parts
    diagram on-line and it appears that the last person in this motor may have
    put these in in the wrong order. The diagram I found shows that the rear
    most ring is called a wave washer. One of the washers is conical in shape
    (spring) the other is flat (washer). mine were installed flat washer first
    conical ring second.
    How are these things supposed to be installed??
    Thanks in advance
    Tom
  2. Useagroves
    CK Guest
    That part is right, according to the parts diagram on
    www.partsfish.com.
    In my opinion, the online parts diagram may be wrong in another way,
    though
    It shows the # 5 hub with the first part going on it being the # 6
    seat, then the # 9 wave washer.
    That part makes sense, if the next part you install is one of the STEEL
    plates.
    But the drawing shows that a FIBER friction plate is the next part.
    That looks WRONG.
    The fiber friction plate would rotate in relation to the wave washer
    anytime the clutch slipped or was intentionally disengaged. The fiber
    plate would wear a groove in itself, or the wave washer would have to
    rotate with it.
    So, the next part installed after the wave washer would logically be a
    STEEL plate. That's how my GS-1100 clutch is stacked. Spring seat, wave
    washer, steel plate.
    The last plate in the stack is a fiber plate.
    CK, Dec 12, 2005
  3. Useagroves
    Useagroves Guest
    Thanks CK.
    Your concern over the stacking order is a good one. However, the order you
    are seeing in your diagram is correct. The washer and the spring reside
    "within" the inner diameter of that fiber plate. They will not contact the
    friction surfaces.
    My concern is with how the spring (Wave Washer) is installed. It is shaped
    like a pie pan with no bottom, or a very very shallow funnell. (this is
    difficult to explain) cross section of a cone, a bearing race, etc..
    Can you tell from the drawing you are looking at which way it is oriented?
    My drawing is not that detailed.
    Thanks man, I appreciate your help
    Tom
  4. Useagroves
    CK Guest
    No, I am looking at the Suzuki parts fiche on www.partsfish.com and it
    doesn't get into the orientation of the spring washer. Neither does my
    Clymer repair manual for the
    GS-1100.
    In fact, the average GS-1100 owner probably never removes the washer
    and seat when re-packing the clutch. There is a spring steel wire
    "stopper" holding the steel plate over the spring and seat.
    Your Intruder's clutch doesn't use the wire stopper.
    CK, Dec 12, 2005
