Voltage query
Discussion in 'Classic Motorbikes' started by Rich B, Jan 6, 2009.
  1. Rich B
    Kim Bolton Guest
    Possibly, athough I've never used an Optimate. But why would you want
    to put a battery on charge just after a run?
    Kim Bolton, Jan 15, 2009
  2. Rich B
    Rusty_Hinge Guest
    Sort run and use of a self-starter to begin with, maybe?
    Rusty_Hinge, Jan 15, 2009
  3. Rich B
    crn Guest
    You need to get out on the bike more often.
    crn, Jan 15, 2009
  4. Rich B
    A.Clews Guest
    Thus spake Kim Bolton () unto the assembled multitudes:
    Just habit. I don't use my bike a great deal, and my habit is just to
    hook it up to the charger immediately (or 15 minutes later) so as to keep
    it topped up until I next use it, which could be several weeks at this time
    of year.
    A.Clews, Jan 15, 2009
  5. Rich B
    Kim Bolton Guest
    A modern (200+W?) alternator should cope with that, if it is set to
    the right voltage, about 14.4V or so. Any lower and it might take the
    battery a little while to recover. However, Andy said that he might
    not ride the bike again for some weeks, so the Optimate makes sense.
    Be interesting if anyone else has noticed the reluctance to go into
    'charge' mode just after a run.
  6. Rich B
    Rich B Guest
    Kim Bolton typed:
    Yup. I put the XT away for Christmas week, as I needed the car a lot at
    work, and I put it straight in the garage after a run and onto the Optimate.
    It reported a shagged battery, then 'desulphating', then shagged. Red and
    orange lights everywhere. I switched it off and left it overnight. Next
    day - no probs. Two greens within ten minutes, and it stayed that way for a
    week.
    Rich B
    1971 S2a
    1995 XT600E
    2003 ST1300 Pan European
    Oh, and a Ford
    Take out the obvious to email me.
    Rich B, Jan 15, 2009
  7. Up to 2.2V per cell for most LA wet cell batteries.
    Grimly Curmudgeon, Jan 15, 2009
  8. Rich B
    Kim Bolton Guest
    Interesting....this might be useful way of estimating how much
    surface-charge there is, by seeing how long it takes for an Optimate
    to report such a battery as 'normal'. Andy has circa 15 minutes, and
    yours appears to be somewhat longer than that. Shorter surface-charge
    discharge times (IYSWIM) might be a very early warning of battery
    deterioration.
    The other thing, if you want to hook your Optimate to the battery, is
    to leave your headlight on while putting the bike away. This should
    remove the surface charge, and enable the Optimate to function
    immediately.
    Kim Bolton, Jan 17, 2009
