voltage conversion puzzle.
Discussion in 'Motorcycle Technical Discussion' started by asd;lkfasdkfln, May 21, 2007.
  1. Hello
    How would I convert 13.2 volts dc from my motorcycle down to 9 volts dc for
    my helmetcam?
    Something in-line in the wire?
    A resistor?
    The camera uses 50 milliamps during operation.
    Please reply to
    Thanks for any replies.
  2. A 3-terminal voltage regulator and a couple of capacitors.
    Dr Ivan D. Reid, May 21, 2007
  3. asd;lkfasdkfln
    Paladin Guest
    Quick, cheap and dirty: a 50 ohm 1/2 watt resister in series with a 9
    volt zener diode to ground.
    Paladin, May 21, 2007
  4. asd;lkfasdkfln
    Paladin Guest
    Checking my math, make that a 60 ohm 1 watt, a 1 watt zener, and if
    you hook the zener up backwards you'll have zero volts out and will be
    smoking the resister.
  5. asd;lkfasdkfln
    Fred W Guest
    You obviously only put the circuit in series with the one component that
    requires the 9V.
    On the bike side of the resistor will still be 13.2V. The load side of
    the resistor would be 9V. The zener diode will only draw enough current
    to drop 4.2V on the resistor at idle (84 ma using a 50 ohm series
    resitor proposed) and would use 352 milliwatts (.084^2 x 50)
    But to properly design this circuit you need to know what the current
    demand of the device is so that you do not drop more than 4.2V when it
    is drawing current though the series resistor. Therefore, it cannot
    draw more than 84 ma.
    Fred W, May 21, 2007
  6. asd;lkfasdkfln
    Fred W Guest
    I don't think you understand how zener diodes work. They are normally
    set-up in reverse bias. Putting it in backwards would be forward
    biasing the diode and you would sink the full 12V to ground until the
    resistor or the Diode fried opened.
  7. asd;lkfasdkfln
    Stephen! Guest
    There... I fixed it for you.
    Stephen!, May 21, 2007
  8. asd;lkfasdkfln
    Bob Nixon Guest
    I don't think they make a 3 pole 7809 regulator, rather 7808, 7812,
    7805... & the negative voltage 7900 series. what you want for exactly
    9 volts is an adjustable 3 pole LM317 regulator with a voltage divider
    (75 ohms) on the ground leg to set up the 9 volts & (25 ohms) on the
    top rail to 12Volts to set up the 9 volt output Also use a 1 uf cap
    from the output to ground to reduce any noise generated by the
    regulator and more importantly to keep the curcuit from oscillating,
    SEE reference below:
    http://www.kitsrus.com/projects/k68.pdf
    An alternative (cheap and dirty method) is to pick up a 9 volt zener
    diode (reverse bias to ground) and a series 50 ohm resistor in front
    in series with the 12 volt line (supply side) and the 1 uf cap on the
    output of the zener diode both in parellel from 12 volts to ground.
    Bob Nixon RZ-350
    Bob Nixon, May 21, 2007
  9. asd;lkfasdkfln
    Mark Olson Guest
    I can't decipher your instructions-- if you are trying to get 9V
    using the circuit in the k68.pdf file referenced above, setting
    R2 to 75 Ohms and R1 to 25 Ohms will give you 5V not 9V. There's
    no need to use such small value resistors, BTW, something in the
    hundreds or even thousands of Ohms would work just as well.
    If you want 9V output, R2 = R1 * 6.2
    Vo = 9V
    Vr = 1.25
    Vo * R1 / (R1 + R2) = Vr
    Vo/Vr = (R1 + R2)/R1
    Vo/Vr = R1/R1 + R2/R1
    Vo/Vr - 1 = R2/R1, plugging in for Vo and Vr gives R2/R1 = 6.2
    Pick something sane for R1 and R2 such as R1 = 330 & R2 = 2k, gives
    about 2% less than 9V, close enough.
    Forget the zener diode method, LM317 is the way to go.
    Mark Olson, May 21, 2007
  10. Holly Crap 1 message turned on the 'light' for me
    Use an inverter from 13 volts to AC.
    Plug in the factory supplied AC. TO DC. 9 Volt adaptor.
    Plug the camera into the 9 volt supply plug.
    A bit of a pile of junk to transport in my backpack but it should work
    I'll use a meter to see the result before plugging in the camera.
    Thanks for the techinical feedbacks and electronics lessons .
    Brian
  11. asd;lkfasdkfln
    matt weber Guest
    You are much better off to go with the 3 terminal regulator and 3
    caps, 1 small (.01uf) , two large (100uf or so).... They are designed
    to be abused. Zener's don't like it and tend to fry at very
    inopportune moments.
    put one big cap between input and ground, another between output and
    ground, and the small ones goes from input to output
    matt weber, May 21, 2007
  12. Gotta love this thread. Talk about a geekfest. ;-)
    How about you buy a $19.95 plug in 12v -> 9V 100ma
    converter from Radio Schlock.
    http://www.radioshack.com/sm-9-volt-vehicle-dc-to-dc-adapter--pi-2102592.html
    I'd be astonished if you had to spend $30 for an
    over-the-counter DC -> DC adapter.
    Forget the 12V -> 120AC -> 9VDC stuff.
    Also forget cobbling one together with diodes
    and resistors.
    Rob Kleinschmidt, May 22, 2007
  13. asd;lkfasdkfln
    Bob Nixon Guest
    The above is correct, I was in too big a hurry. Mine would be fine for
    and unloaded voltage divider but that's not what an LM 317 is. BTW, we
    all should have allowed for a working running bike regulated voltage
    od 13 volts instead of 12 volts.
    Bob Nixon, May 22, 2007
  14. A couple of bucks and an hour's work.
    I picked up one at West Marine a couple years back.
    A reasonable addition to any bike.
  15. asd;lkfasdkfln
    phil scott Guest
    there are some real smart replies in the stack here... however a
    person could run the camera off of a small 9v battery for 5 dollars
    and skip tying to power it from the bike... a battery might run the
    thing for hours at a time.
    Phil Scott
    phil scott, May 22, 2007
  16. asd;lkfasdkfln
    Darby OGill Guest
    50 ma at 9 vdc semms like 180 ohm r. To drop 9vdc on this load and 4.2
    (9+4.2=13.2) on a series load , use around an 85 ohm resister.....doest this
    sound right?....not sure I try with my bike and camera though.
    Darby OGill, May 22, 2007
  17. asd;lkfasdkfln
    dizzy Guest
    Clueless.
    dizzy, May 22, 2007
  18. asd;lkfasdkfln
    Bob Nixon Guest
    1st off, give me a little credit. I knew the divider was on the output
    side (between top rail third leg & ground. However my main concern
    with the 13 or even 14 regulated volage is the heat dissapation of
    that 4-5 volts across the LM317. It should handle 5 volts @100 mills
    easily if the properly mounted epoxy package LM 317 has the metal
    backside flat on unpainted metal.Otherwise that half watt (100mills X
    5 volts) could eventually fail from continuous over heating. Just
    playing on the safe side:)
  19. asd;lkfasdkfln
    zammy Guest
    you can usa a Zener diode to drop it, or use the voltage
    drop in a series of common doides to do the same,
    or purchase a dc-dc convertor which costs quite a lot. ~$75.
    the cheap diodes have a forward drop of about 2/10 of a volt drop each.
    sam
    zammy, May 23, 2007
  20. asd;lkfasdkfln
    Fred W Guest
    That's the second person that has recomended using a bunch of series
    diodes. Why on earth would you use diodes instead of a single series
    resistor? Either way (diodes or resistors) there would not be any
    regulation of the 9v with variations of battery (supply) voltage and the
    output 9V would vary under varying load (current).
    A 9.1V zener diode and a series resistor selected for the appropriate
    nominal voltage drop at peak device load would be a more elegant
    solution. The zener would only sink current (and consume power) when
    the input voltage gets too high or under less than peak load.
    If this is too simple, you could build the regulator circuit shown on
    this web page for a couple of bucks:
    http://www.uoguelph.ca/~antoon/circ/car912.htm
    Here is a web page that shows all of the solutions people have been
    talking about:
    http://www.cpemma.co.uk/diodes.html
    Fred W, May 23, 2007
