Volcano ash.
Discussion in 'UK Motorcycles' started by ian field, Apr 17, 2010.
  1. Using the patented Mavis Beacon "Hunt&Peck" Technique, Charlie
    We'll soon whip this thread into shape.
    Wicked Uncle Nigel, Apr 21, 2010
  2. ian field
    Adrian Guest
    Not to mention the restriction on airflow inherent in a filter fine
    enough to get all the ash out - and the consequences of a filter failing
    and collapsing...
    I don't think whoever suggested filters really knew anything much about
    jet engines.
    Adrian, Apr 21, 2010
  3. ian field
    We'll need to crack on a bit.
    Ace, Apr 21, 2010
  4. ian field
    'Hog Guest
    For Prop planes sure, they have anyway. Turboprops, maybe just. Large wing
    mounted Turbofans, no way as they ingest EEK cubic metres of air per
    second.
    I wonder how often the fan and compressor blades get changed in normal
    service.
    'Hog, Apr 21, 2010
  5. ian field
    crn Guest
    Some turboprops are reverse flow such as the PT6. These have an inertial
    seperator[1] but the volcano dust might not be heavy enough for this to
    work.
    [1] Inlet pipe with a 180deg bend, water and ice crystals go straight on
    instead of round the bend and are dumped overboard.
    crn, Apr 21, 2010
  6. ian field
    'Hog Guest
    I know, I wonder if some military jets do the same with turbojets that are
    ducted from the front of the fuselage.
    'Hog, Apr 21, 2010
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Charlie
    Why hasn't Cane responded to this thread?
  8. ian field
    Roger Hunt Guest
    Wasn't abel - busy feeding the cat.
    Roger Hunt, Apr 21, 2010
  9. ian field
    ian field Guest
    Bit of a bumpy launch from the steam catapult ramp tho'.
    ian field, Apr 21, 2010
  10. ian field
    You've been watching too much tv.
    Andy Bonwick, Apr 21, 2010
  11. ian field
    I suspect they have different priorities.
    Pip Luscher, Apr 21, 2010
  12. ian field
    Or maybe kissing the gunner's daugher.
  13. Or showing off the golden rivet.
    Grimly Curmudgeon, Apr 21, 2010
  14. ian field
    Cab Guest
    Champ wibbled forthrightly:
    What's the point? Events like this aren't exactly common.
    Cab, Apr 22, 2010
  15. ian field
    Well we might be approaching the Second Age of Vulcanism. Or something.
    No Trekkie jokes now....
    Hog, Apr 22, 2010
  16. ian field
    Tyred of them are we?
    Pip Luscher, Apr 22, 2010
  17. Exactly, plus the efficiency reduction on a jet engine having a filter
    would reduce what we are trying to do for C02 reduction, let alone the
    extra cost for tickets as the aircraft have to burn more fuel to get
    anywhere. We've got so used to getting anywhere instantly I think we
    have forgotten that we are a speck on this planet and when Mother
    Nature wants to play games, she will win every time.
    Kev
    Kevin Gleeson, Apr 22, 2010
  18. ian field
    geoff Guest
    Strangely, I've just read a 2 year old NS which says that the magma is
    too cool, that it's probably cut off from its source and unlikely to do
    anything spectacular again
    geoff, Apr 23, 2010
  19. ian field
    I'd tread carefully IIWY.
    Ace, Apr 23, 2010
  20. ian field
    Who?
    Pip, Apr 23, 2010
Similar Threads
Loading...
