VMax wheel swap?
Discussion in 'UK Motorcycles' started by Dave H., Oct 17, 2003.
  1. Dave H.
    Dave H. Guest
    Hi Chaps, Chapesses,
    no radials are available in the 150/90/15 size fitted to the back of
    VMaxen, :eek:( so
    I'm contemplating emptying my wallet and getting a conversion for the rear
    wheel to a 17" or 18" so I can run more modern (i.e. radial) tyres - a
    popular mod I believe? Has anyone on the group tried this on a "take it to
    the local
    engineering works / machine shop" basis, rather than sending it all off to a
    VMax specialist and paying out £1000? I'd be interested to hear of any
    pitfalls along the way, but I guess it involves:
    Taking a VMax rear wheel and machining the rim and spokes off;
    taking the replacement wheel and machining out the original hub;
    aligning 'em and tacking into place, then checking runout on a spindle with
    DTI gauges etc;
    making the final TIG welds to attach the two;
    checking again;
    cursing and starting over ;o)
    I'd guess that due to the size of the VMax hub and cushdrive, most superbike
    wheels would be suitable, the majority of hubs seem substantially smaller!
    Locally, there's a fella with his VMax's wheels converted - Thundercat front
    (with
    a little machining for clearances etc), Thundercat rim and spokes on the
    VMax hub rear.
    I guess that the accuracy of the alignment is pretty critical, but I've seen
    new stock wheels on bikes that had as much as .075" runout both radially and
    laterally (and occasionally more....), and the bikes seemed to handle OK....
    in the past I've build trad wire-spoked wheels, and I've always aimed for a
    max of .020" runout, and the wheels have felt smooth, no vibration, compared
    to badly tensioned spoked wheels - and I guess that balance would be pretty
    important (ain't it always?)
    Any thoughts welcome,
    Dave H.
    (The engineer formerly known as Homeless)
  2. "Dave H."
    read some where that diversion 900s rear wheel fits
    Cyril Bonnett, Oct 17, 2003
