virago xv535 replace rear shocks? Advice needed
Discussion in 'Motorbike Technical Discussion' started by seabreeze, Oct 9, 2007.
  1. seabreeze
    seabreeze Guest
    Hi. I have a 1996 XV535 that has done about 5k miles. I find the
    suspension harsh over small bumps, typical of urban streets, these
    aggravate my back something rotten. I recently rode 170 miles around
    Samos in Greece on a 125cc scooter, on some very rough roads with no
    problem at all, I doubt I would have lasted a quarter of that on the
    virago. I'm about 6 ft tall, and weigh about 75 kg and am thinking
    about changing the rear shocks having already tried setting the
    preload to the softest setting. Hagon seem a good choice as they are
    reasonably priced and can do custom jobs to order. I am thinking of
    slightly softer shocks as I only take a pillion occasionally, and
    longer ones to both extend the travel of the shock, and height of the
    saddle slightly. Standard shock length is I think 11.25", and am
    thinking of extending to say 12.5". Is this sensible? Opinions/
    suggestions gratefully received.
  2. seabreeze
    seabreeze Guest
    Hi, thanks for advice. Yes, have already set them to the softest
    setting.
  3. Hagon are good, yes.
    That's quite a change. It will almost certainly result in quicker
    steering, which may or may not be a good thing. It will also increase
    ground clearance, which is no bad thing on a cruiser. However, I would
    not make that radical a change if it was my bike.
    Sounds silly, but have you tried adjuster the standard shocks to a
    softer setting?
    The Older Gentleman, Oct 9, 2007
  4. FFS. We all know what he meant.
    No, you don't.
    Which means welding new mounts to the frame, you silly bastard.
    No you don't, not for a Virago. You try some softer shocks and see how
    it feels.
  5. seabreeze
    M.Badger Guest
    Typical tale of OEM suspension units. Most of my bikes have had their
    suspension units replaced with Hagon. Do it, you won't regret it. They are
    a good compromise between price and performance. On the Virago, before you
    go fitting longer units, trawl the owners forums for posts relating to any
    issues.
    M.Badger, Oct 10, 2007
  6. My experience completely. I've got them on my 400 Four and have had them
    on other bikes. They're surprisingly well finished, too. Better than a
    lot of Far Eastern stuff.
    Good advice.
    The Older Gentleman, Oct 10, 2007
  7. seabreeze
    seabreeze Guest
    In reply to my own question even, I just came across the Progressive
    US website that lists products for the XV535, and what they suggest
    is:
    - A4 The shock recommended is slightly longer than stock. This may
    alter the head angle slightly and give somewhat quicker steering.
    A16 Approximate stock shock length is 11.75" -
    Sizes offered for this bike are from 11" to 12.5", with the largest
    choice of options being for the 12.5", so I am guessing that is their
    suggestion.
    http://www.progressivesuspension.com/prodSearchResults.aspx?yearID=1996&makeID=48&modelID=511
    seabreeze, Oct 13, 2007
  8. Buy a stock length shock. Buy Hagon. Cheap, reliable, work well, and the
    company knows what it's doing. Forget all this guff about measuring
    springs - order a pair from Hagon, and they'll delight you with the
    improvement over stock.
    A 535's suspension is compromised enough as it is, so you'll never get
    it to feel like a plush tourer.
    Nice bike, the 535. My favourite small Jap custom bike.
    The Older Gentleman, Oct 15, 2007
  9. seabreeze
    seabreeze Guest
    Thanks very much for the advice and help - it's not a simple decision
    as funds are fairly limited. What I will do I think is check non-
    loaded length, static sag (no rider) and sag with rider (me) in riding
    position, and see if the standard shocks with my weight tally with
    what is generally considered normal for most bikes. Then have a word
    with Hagon and see what they suggest - I agree, that they will
    possibly just want to sell me whatever, with possibly little in the
    way of research in terms of effects; what is clear is that I need a
    good idea of how whatever I choose to do with it will affect handling,
    and how spring rates etc will affect the general behaviour of the
    bike. I am tempted towards changing the length and stiffness a little
    because if I don't I might then wonder it it might have been better to
    do so; and of course on the other hand there is the issue is that the
    stock length and spring rate is how the manufacturers originally
    designed the bike to be made and set up for riding.
    Will post again and let you know.
    seabreeze, Oct 17, 2007
  10. That's not a bad route to take.
    Trouble here is that cruisers are generally set up with softish
    suspension, whereas sports bikes aren't. There's no hard and fast rule.
    I think you're doing them down unnecessarily. Believe me, they *really*
    know their stuff. I was in their factory/warehouse about a month ago.
    Hagon will advise. Listen to them.
    Yes and no. Standard isn't always best (cost constraints, plus the fact
    that riders differ widely in terms of weight and riding style) but it's
    usually a pretty good place to start.
    The Older Gentleman, Oct 17, 2007
