I am wondering about the valve adjustment on my 91 virago 750. When i bring the cylinders to TDC on the compression stroke (verfied by timing marks under ignition cover) the valves are closed and the the rockers are loose( i can wiggle them) but this is not the spot of the widest gap. When i rotated the piston to BDC with the intake valve open there is more gap on the exhaust valve than at TDC on compresson stroke. Same goes for intake valve when the exhaust valve is open and same thing on both cylinders. There are no timings marks at these positions. Why wouldn't the gap be more at TDC? Last adjustment i rotated the engine to find the largest gap and set that gap at spec. This time i tried it using timing marks and now have some valve noise i didn't before, mainly at idle and just off idle. Not excessive but noticeable. Before i readjusted i checked the clearance at TDC and couldn't get a .002" feeler in but could wiggle the rocker. I am thinking that the clearances need to be at spec at TDC with the timing marks lined up but why is the gap appr .003" more at te other position?? The bike runs fine and no noticeable difference after re-adjusting the valves, just a little more noisy. Also are the marks an I for the front and an "F" (with quotes)for the rear?(i know i need a manual!) TIA for comments, Dev
